I'm trying to configure my ATMEGA328p to measure temperature using the TMP36GZ temperature sensor. However, the 10-bit ADC keeps returning 1023. I've tried disconnecting the temperature sensor (it should return 0 at this point for the ADC reading), but it still returns 1023. I'm not exactly sure what I'm doing wrong in my code:
volatile uint16_t TMP36_VoutADCReading = 0U;
void TMP36_Init( void )
// Set the ADC prescaler to 128 (i.e., 16MHz/128 = 125KHz)
ADCSRA |= ( 1 << ADPS2 ) | ( 1 << ADPS1 ) | ( 1 << ADPS0 );
// Set the voltage reference from AVcc (i.e., 5V).
ADMUX |= ( 1 << REFS0 );
// Turn on the ADC.
ADCSRA |= ( 1 << ADEN );
// Do the initial conversion (i.e., the slowest conversion)
// to ensure that everything is up and running.
ADCSRA |= ( 1 << ADSC );
void TMP36_ADCRead( uint8_t channel )
// Clear the previously read channel.
// ADCSRA &= 0xf0; <-- This was causing the bug.
ADMUX &= 0xf0; // <-- This is the fix. Thanks IgnacioVazquez-Abrams!
// Select the ADC channel to be read.
ADMUX |= channel;
// Start a new conversion. By default, this conversion will
// be performed in single conversion mode.
// Wait until the conversion is complete.
// while( ADCSRA & ( 1 << ADSC ) ); <-- This is probably also correct.
while( ADCSRA & ( 1 << ADIF ) ); // <-- Added. Thanks Adithya!
// Obtain the ADC reading from Vout.
TMP36_VoutADCReading = ADC;
// Clear the ADIF flag.
ADCSRA |= ( 1 << ADIF ); // <-- Just added. Thanks Adithya!
int main( void )
// Disable all interrupts for the time being.
cli();
// Initialize the TMP36GZ temperature sensor.
TMP36_Init();
// Enable all interrupts.
sei();
while( 1 )
// Compute the distance.
uint8_t channel = 1;
TMP36_ADCRead( channel ); // At this point, TMP36_VoutADCReading = 1023
In terms of connections, I'm trying to read the output voltage from pin PC1 on the ATMEGA328p and I have AVcc connected to VCC and pin 22 (i.e., GND) connected to pin 8's GND. I have disabled setting the voltage reference from AREF, so AREF isn't connected.
Any help would be greatly appreciated.
UPDATE:
IgnacioVazquez-Abrams pointed out that ADCSRA &= 0xf0;
should have been ADMUX &= 0xf0;
. I've since modified the code above. Also, thanks Adithya for the suggestion you made about checking the ADIF flag! I'll take it into consideration.
ADMUX
then. \$\endgroup\$
