hello I'm new here and I have a question. I'm no electronics expert but what I'm trying to do I thought would be rather simple but I'm having trouble with one part hopefully somebody can help me.
I'm trying to put togther something for Haloween, what I've got is a doormat that says happy Haloween on it, I rigged it up so when it's stepped on it closes a circut, last year I used it to turn on a light. this year I want to use it so when it's stepped on it turns on my fogger for 3 seconds then stops until it's stepped on again. so that way I can put the doormat at the begining of my walkway and when someone steps on it the fogger I've placed about halfway up my walkway will shoot a 3 second burst of fog about knee high across the path they have to walk through to get to my door. like I said before it sounds simple and I've got everything else pretty much figured out but the 3 sec on time is harder than I thought. I need something that can activate when it receives a quick shot of low voltage dc from when the mat is stepped on and let low voltage dc flow through it for 3 seconds than shut off until it gets another shot from the mat. that way I can run lvdc through it to activate a relay that will switch on a 120 ac circuit for 3 seconds to run the fogger. so I guess what I kind of need is a relay that when it gets a quick shot of juice will only run for 3 sec then shut off until the next shot. now the only thing that HAS to be lvdc is the doormat part I don't want to run 120 ac through that part and risk shocking anyone.
can someone please help me?
