I have migrated from a 16x2 alpha-numeric display to a 128x64 graphical in existing project. With that in mind, I am planning on using a larger font instead of the "easy" 5x7. How do I integrate TTF font file in C?? How to generate hex for the same?
  • \$\begingroup\$ Have you tried using your toolchain's tool for converting binary files into object code? \$\endgroup\$ Oct 27, 2014 at 6:21
  • \$\begingroup\$ I didn't get you \$\endgroup\$
    – spp
    Oct 27, 2014 at 6:28
    \$\begingroup\$ I have used MuGUI for this. \$\endgroup\$
    – David
    Oct 27, 2014 at 7:31
TTF is a vector font format, you first need to convert it into a bitmap with 1 bit color depth, then load it as an array in your code.
GIMP can save the bitmap as a C array.
  • \$\begingroup\$ Unless the rest of your C code includes a TTF renderer. \$\endgroup\$ Oct 27, 2014 at 7:53
  • \$\begingroup\$ Good luck doing that on a low resolution LCD, probably with a small (<256KB RAM) fixed point only MCU... \$\endgroup\$
    – Lior Bilia
    Oct 27, 2014 at 19:31
