I have an Arduino Uno and am running a sketch with lots of variables (23 constant char arrays that have 54 object in each array). Along with all these variables there is lots of if statements. The project controls an RGB LED neopixel strip where each LED is independent (WS2812 based). This code runs fine under the Uno and the LEDs flash as expected. However when I put the code on the ATtiny85 they all flash randomly or some turn on and stay on. The code compiles and loads with no errors on the Attiny85. I am not sure what is going on that would cause it to not work? Any help is much appreciated!
I am defining the arrays like so const char arrayName[] =
and I was wondering if that is the issue because there is so many?
The code is to do an RGB LED word clock. The reason I would like to use an Attiny is 1. I already have it (but I could buy something else that is not totally unacceptable). and 2. it is small enough to fit in the case.
I could buy another chip, but would like to understand the limitations and why it doesn't work before buying another chip.
If it is not possible to get this working on the Attiny85 then is there an alternative small chip that would work?
Below is the code - with the exception of right now it is setup for serial println instead of the actual RGB LED output. Is there a more efficient way that might solve the problem?
const char it[] = {'1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char is[] = {'0','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char mten[] = {'0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char half[] = {'0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char twenty[] = {'0','0','0','0','0','0','1','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char quarter[] = {'0','0','0','0','0','0','0','0','0','1','1','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char mfive[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char minutes[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char two[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char one[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char to[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char past[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char three[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char four[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char five[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char eight[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char seven[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char six[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0','0','0'};
const char nine[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0','0','0'};
const char ten[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0','0','0'};
const char eleven[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','1','0','0','0','0','0','0'};
const char oclock[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','1','0','0','0'};
const char twelve[] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','1','1','1'};
char pins[55] = {'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','\0'};
int red = 50;
int grn = 0;
int blu = 0;
uint8_t oldminute = 0;
void setup () {
void editPins(const char add[]) {
for (int a = 0; a < 54; a++) {
if (add[a] == '1') {
pins[a] = '1';
void loop () {
uint8_t hourvalue, minutevalue;
hourvalue = 8;
minutevalue = 13;
for (int x = 0; x < 55; x++) {
pins[x] = '0';
if ((minutevalue>4) && (minutevalue<10)) {
editPins(mfive);
editPins(minutes);
if ((minutevalue>9) && (minutevalue<15)) {
editPins(mten);
editPins(minutes);
if ((minutevalue>14) && (minutevalue<20)) {
editPins(quarter);
if ((minutevalue>19) && (minutevalue<25)) {
editPins(twenty);
editPins(minutes);
if ((minutevalue>24) && (minutevalue<30)) {
editPins(twenty);
editPins(mfive);
editPins(minutes);
if ((minutevalue>29) && (minutevalue<35)) {
editPins(half);
if ((minutevalue>34) && (minutevalue<40)) {
editPins(twenty);
editPins(mfive);
editPins(minutes);
if ((minutevalue>39) && (minutevalue<45)) {
editPins(twenty);
editPins(minutes);
if ((minutevalue>44) && (minutevalue<50)) {
editPins(quarter);
if ((minutevalue>49) && (minutevalue<55)) {
editPins(mten);
editPins(minutes);
if (minutevalue>54) {
editPins(mfive);
editPins(minutes);
if ((minutevalue <5)) {
if (hourvalue==1) {
editPins(one);
if (hourvalue==2) {
editPins(two);
if (hourvalue==3) {
editPins(three);
if (hourvalue==4) {
editPins(four);
if (hourvalue==5) {
editPins(five);
if (hourvalue==6) {
editPins(six);
if (hourvalue==7) {
editPins(seven);
if (hourvalue==8) {
editPins(eight);
if (hourvalue==9) {
editPins(nine);
if (hourvalue==10) {
editPins(ten);
if (hourvalue==11) {
editPins(eleven);
if (hourvalue==12) {
editPins(twelve);
editPins(oclock);
} else
if ((minutevalue < 35) && (minutevalue >4)) {
editPins(past);
if (hourvalue==1) {
editPins(one);
if (hourvalue==2) {
editPins(two);
if (hourvalue==3) {
editPins(three);
if (hourvalue==4) {
editPins(four);
if (hourvalue==5) {
editPins(five);
if (hourvalue==6) {
editPins(six);
if (hourvalue==7) {
editPins(seven);
if (hourvalue==8) {
editPins(eight);
if (hourvalue==9) {
editPins(nine);
editPins(ten);
editPins(eleven);
editPins(twelve);
} else {
// if we are greater than 34 minutes past the hour then display
// the next hour, as we will be displaying a 'to' sign
editPins(to);
if (hourvalue==1) {
editPins(two);
if (hourvalue==2) {
editPins(three);
if (hourvalue==3) {
editPins(four);
if (hourvalue==4) {
editPins(five);
if (hourvalue==5) {
editPins(six);
if (hourvalue==6) {
editPins(seven);
if (hourvalue==7) {
editPins(eight);
if (hourvalue==8) {
editPins(nine);
if (hourvalue==9) {
editPins(ten);
editPins(eleven);
editPins(twelve);
editPins(one);
for (int x = 0; x < 54; x++) {
if (pins[x]=='1') {
Serial.println(x);
delay(5000);
