Is it true that the higher the resistance the higher voltage would drop?
closed as unclear what you're asking by Keelan, Daniel Grillo, placeholder, Dave Tweed Oct 28 '14 at 17:58
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Generally, in a circuit where the current travels through two or more resistances, increasing one R in isolation will increase V across it. \$\endgroup\$ – Russell McMahon Oct 28 '14 at 10:06
No. This is only true if the current stays the same.
Imagine a single resistor across a battery. Regardless of the battery voltage and the resistor value, the resistor has to drop all that voltage.
Now a imagine a constant current source instead of the battery. Now the higher the resistor the higher the voltage drop because the current source forces more power through the same resistor as R increases.
