Total noob here.
The tech sheet can be found here: http://www.ti.com/lit/ds/symlink/sn74as138.pdf
In the VOH parameter for the SN74AS138 on page 5, it states that it's MIN is VCC-2.
What does that mean? What is referring to? Is it referring to the actual VCC minus 2 volts? So 2.5V for VCC = 4.5V?
Here's the snippet I'm talking about:
Snippet from datasheet
It is a simple sum.
It refers to the output voltage when an output is HIGH (\$V_{OH}\$) as a minimum (it's in the MIN column) of 2 volts below \$V_{CC}\$, so if \$V_{CC} = 5V\$ then \$V_{OH}\$ will be at least 3V.
For CMOS you will often see something like \$0.6V_{CC}\$, where the value is 60% of the \$V_{CC}\$ value.
It refers to the pin diagram on the first page, where Vcc is pin 16.
On page 4 of the datasheet, you see:
So it's the supply voltage of the IC.
Also see this: http://en.wikipedia.org/wiki/IC_power-supply_pin - excerpt:
Typical supply pin labeling:
VCC / VDD / V+ / VS+ : Positive supply voltage
VEE / VSS / V / VS− : Negative supply voltage
And exactly, VCC - 2 refers to 'the supply voltage minus two volts'.
