It is easy to find BLDC motor manufacturers on google, but it is difficult to find PMSM. Maybe there is a terminology issue here. There are many "Brushless Servo Motors" or "Synchronous Servo Motors" on google, do manufacturers use these terminologies to refer to PMSM motor?
In theory: BLDC has concentrated stator windings and trapezoidal back EMF, the controling method is called "6-step commutation". PMSM has distributed stator windings and sinusoidal back EMF, the controling method is called "FOC".
In reality: Most so called BLDC motors on the market have sinusoidal back EMF, and can be controlled by the same FOC method as PMSM motor. But I think they are still BLDC motor, not PMSM.
My question is: Is "Brushless/Synchronous Servo Motors" more like the theoretical PMSM motor? What does manufacturer call PMSM motor?
Thank you.
  • \$\begingroup\$ It's kind of Ironic that you come here to find out the differences between PMSM and BLDC and you can't find the term, but no where do you actually define it. Put the definitions of PMSM in your write up. \$\endgroup\$ Oct 28, 2014 at 14:31
  • \$\begingroup\$ Specifically, why do you need a PMSM and why is a BLDC motor insufficient? \$\endgroup\$
    – user16324
  • \$\begingroup\$ PMSM = Permanent Magnet Synchronous Motor. This exact question came up a couple of days ago. \$\endgroup\$
    – user16324
    Oct 28, 2014 at 14:32
7
The terminology for brushless, permanent magnet motors is confusing.
If you look in academic/technical literature like IEEE papers, then generally BLDC refers to brushless PM motors that have a trapezoidal back-emf and is driven by a six-step, trapezoidal drive, while PMSM refers to brushless PM motors that have a sinusoidal back-emf and are driven by sinusoidal waveforms. Be aware that brushless motors with a trapezoidal back-emf can be driven by sinusoidal waveforms and vice versa. And also be aware that trapezoidal and sinusoidal back-emf's are ideals and you can never really get either one. Of course, I've also seen IEEE papers that refer to BLAC motors and use other terminology, so this isn't strict across the board.
Industry hasn't really adopted this terminology completely. You often will see companies refer to BLDC motors, as you've already pointed out. And generally by BLDC they mean exactly what the academics mean - a brushless motor with a trapezoidal back-emf. However, I've also seen these referred to DC brushless (DCB) motors, brushless PM (BPM) motors, or even PMSM's.
With what academic literature refers to as PMSM's, I've seen them called PMSM's, brushless AC (BLAC) motors, AC servo motors, brushless servomotor (BLSM) and others.
Some manufacturers may not make a distinction between the 2 because in reality it isn't an either/or thing. You can't make a brushless motor with a perfect trapezoidal back-emf and you can't make one with a perfect sinusoidal back-emf. Your best bet is to talk directly to manufacturers and tell them what you want to do and they will guide you in the right direction.
This may or may not be true. In my experience, BLDC motors do not have sinusoidal back-emf; they are much closer to trapezoidal. Keep in mind that we are talking about the phase back-emf, not the line-to-line back-emf. Sometimes the line-to-line back-emf looks close to sinusoidal while the phase back-emf doesn't.
  • \$\begingroup\$ Thank you for your thorough explaining. I think BLAC(PMSM) has smoother performance than BLDC, is it true? \$\endgroup\$
    – Ron Mao
    Oct 29, 2014 at 0:44
  • \$\begingroup\$ +1. Good explanations. Even though explanations probably make it worse :-) \$\endgroup\$
    – Russell McMahon
    Oct 29, 2014 at 13:20
  • \$\begingroup\$ @RonMao - The "smoothness" of the performance of a brushless motor depends on how much torque ripple it has. Torque ripple is caused by cogging torque, a mismatch between back-emf shape and current shape, harmonics, non-ideal commutation and other factors. Ideally, you can get ripple-free torque with both BLDC (square-wave back-emf and currents) and BLAC (sinusoidal back-emf and currents) motors/drives, but in practice it is easier to manufacture motors and drives that produce sinusoidal back-emf's and currents, so BLAC's are generally used when you need "smooth performance." \$\endgroup\$
    – Eric
    Oct 29, 2014 at 15:18
  • \$\begingroup\$ has anyone actually seen an off-the-shelf motor with significant back-emf harmonics? Most of the ones that I've seen which are "BLDC" are still fairly sinusoidal. \$\endgroup\$
    – Jason S
    Apr 6, 2020 at 19:38
  • \$\begingroup\$ "Sometimes the line-to-line back-emf looks close to sinusoidal while the phase back-emf doesn't." -- uh... no, that's not how it works. At least, not line-to-neutral. Line-to-ground maybe, but in that case a motor drive is involved and it can look like anything. \$\endgroup\$
    – Jason S
    Apr 6, 2020 at 23:14
For starters:
  1. PMSM: Permanent Magnet Synchronous Machine
  2. BLDC: Brushless Direct Current Machine
  3. BLAC: Brushless Alternating Current Machine
Here is the thing. These three types of machines are essentially the same. PMSM is an umbrella term covering BLDC and BLAC as these two machine types are synchronous machines and differ only in their magnetic circuits (producing a trapzoidal shaped BackEMF or sinus)
You can control a BLDC machine with a SVM sinus controller and equally a BLAC machine with a quasi-squarewave controller. They may not achieve the same performance results (as the stator flux will not match the airgap flux) but they will work
This is NOT my area of expertise. But I don't think there is a terminology issue. I think there are a lot more applications for so-called brushless DC motors than so-called permanent magnet synchronous motors. Consequently, there are more offerings of them. One small tip, if you are looking for PMSM's they are probably a subset of "AC motors," whereas the BLDC's may be under "DC motors," or their own category. It doesn't seem like companies that make BLDC's make PMSM's or vice verse. So finding both in one place may not be common. But a lot of the places that sell induction motors also sell PMSM's.
  • \$\begingroup\$ I'm on the fence about downvoting. I have worked with motors from numerous manufacturers and have never seen a manufacturer offer both PMSM and BLDC motors. Usually it's just BLDC, and even then they may have sinusoidal or near-sinusoidal back-emf. \$\endgroup\$
    – Jason S
    Apr 6, 2020 at 19:36
  • \$\begingroup\$ @JasonS you are probably the only person who has ever read this answer. But do what you feel you must. \$\endgroup\$
    – user57037
    \$\begingroup\$ feedback to you is more important than the rating / gamification -- no downvote. \$\endgroup\$
    – Jason S
    Apr 6, 2020 at 23:15
  • \$\begingroup\$ I went ahead and edited it. Just in case someone reads it some day. \$\endgroup\$
    – user57037
    Apr 7, 2020 at 2:00
