11
What is impedance matching?
Why it is used?
Any kind of electrical power transfer has a typical ratio of voltage to current. For example, you can deliver 100 watts by 1 amp at 100 volts, or 10 amps at 10 volts, or any other product that comes to 100. It's convenient to express the ratio of volts to amps as a number of ohms (since dimensionally that's all ohms are anyway). Power sources, loads, and even transmission lines all have characteristic impedance, which tells you something about what will happen when things are connected together.
Impedance matching is the selection of components with identical impedance, or the addition of impedance transforming components to cause a component with an undesired impedance to appear as though it has a more desirable one.
As Brian Carlton pointed out, when you have matched impedance, you achieve maximal power transfer. This is often desirable, but not always. The thing to remember is that maximal power transfer is achieved at the cost of dissipating equal power in the source and the load.
So for example, a case for not matching impedance is when you want to efficiently use the energy from a source. A 0.1 ohm load would get optimal power out of a battery with a 0.1 ohm internal resistance, but half the energy would be dissipated in the battery itself, which would be rather wasteful of the stored energy. (Not to mention that the terminal voltage would fall to half!) By purposely using a load much with much higher resistance than the battery, most of the stored energy ends up doing work in the load.
On the other hand, you DO want to match impedance when, for example, you have an audio amplifier stage that ideally wants to drive a 600 ohm load, but you only have a 3.2 ohm speaker. An ordinary transformer, having a 1:N voltage ratio, will conveniently give you a 1:N^2 impedance ratio. Another common case is in RF work, where as volting pointed out, you need to minimize reflections, because reflected energy can cause excessive power dissipation in your source.
  • \$\begingroup\$ you dont explain why the power transfer is maximum when the load impedance matches exactly to source impedance. All the explanations I have seen are based on mathematics. I liked your way of explaining it conceptually. \$\endgroup\$
    – 0xakhil
    Jul 19 '11 at 15:12
To maximize power transfer to the load.
  • 6
    \$\begingroup\$ and to minimize signal reflections \$\endgroup\$
    – volting
    Apr 28 '11 at 19:31
    \$\begingroup\$ @volting - different side of the same coin \$\endgroup\$
    – JustJeff
    Apr 28 '11 at 21:08
  • \$\begingroup\$ @JustJeff thats true, I still think it was worth mentioning. \$\endgroup\$
    – volting
    Apr 28 '11 at 21:15
  • \$\begingroup\$ @volting - indeed. so +1 \$\endgroup\$
    – JustJeff
    Apr 28 '11 at 22:42
Impedance matching is simply how to maximise the power of the load, when we want to get the maximum power out of a power source, typically when it's an information signal. This becomes an issue when the load is in series with some impedance, like a transmission line.
In a simple case this can be modelled as a circuit where you have the power source, a resistor representing the resistance of the source, and a resistor representing the resistance of the load.
We can then calculate power of the load as
$$P = \frac{R_LV^2}{(R_S+R_L)^2}$$
Because the power is the V drop over the resistance of the load times the current, and the V drop over the load is $$\frac{R_LV}{R_S+R_L}$$ i.e. the ratio of the load in the total resistance of the circuit multipled by the total potential change, and the current is obviously $$\frac{V}{R_L+R_S}$$
P wrt. RLhas a plot: enter image description here
When using 1V and RS = 0.1, you can see that RL has maximum power when RL = RS.
