In a project involving a serial communication and an Arduino I would like to use the serial interface to run multiple routines on the board.
The idea is to send a unique string with tags and values in order to execute several istructions at the same time. Let's say that we want to set the heading of an aircraft to 180°, the altitude to 3 meters and 20 cm from the ground and to maintain a horizontal profile with roll and pitch angle of 0°. The string would be:
X,heading,180,roll,0,pitch,0,altitude,3.20,X
For simplicity's sake I'll suppose to send a less complex string such as:
X,tag1,tag2,tag3,val3,X
X,Roll,Con,Kp,1.12,X
In order to receive and elaborate the string I've tried using 3 arrays of chars and a few counters. Here is the code:
byte byteRead;
// Store decimal numbers, determine decimal point
double num1, num2;
double complNum,counter;
int numOfDec;
boolean mySwitch=false;
// Use a boolean var to enter in the command receiving mode.
// If you are interpreting several commands type this could be a way
boolean cmplx = false;
// arrays to store tags
char opt1[3];
char opt2[3];
char opt3[2];
// Counters to determine tags
int optCount=0,letterCount=0;
void setup()
Serial.begin(9600);
num1=0;
num2=0;
complNum=0;
counter=1;
numOfDec=0;
void loop()
/* check if data has been sent from the computer: */
while (Serial.available())
/* read the most recent byte */
byteRead = Serial.read();
if (byteRead == 'X')
if (!cmplx)
// begin of the string
cmplx = true;
else
// end of the string - reset values
cmplx=false;
optCount=0;
/* Create the double from num1 and num2 */
complNum=num1+(num2/(counter));
/* Reset the variables for the next round */
// Debug Stuff ignore it
Serial.println();
Serial.print(" opt1: ");
Serial.print(opt1);
Serial.print(" opt2: ");
Serial.print(opt2);
Serial.print(" opt3: ");
Serial.print(opt3);
Serial.print(" NUMBER: ");
Serial.print(complNum);
Serial.print(" letterCount: ");
Serial.print(letterCount);
Serial.print(" optCount: ");
Serial.print(optCount);
// How to reset arrays?
opt1[0] = (char)0;
opt2[0] = (char)0;
opt3[0] = (char)0;
num1=0;
num2=0;
complNum=0;
counter=1;
mySwitch=false;
numOfDec=0;
if (byteRead==44)
// Comma
optCount++;
// Debug stuff
Serial.println();
Serial.print("Virgola numero: ");
Serial.println(optCount);
letterCount = 0;
// Listen for a capital letter or a normal one
if ((byteRead>=65 && byteRead<=90) || (byteRead>=97 && byteRead<=122))
// Debug stuff
Serial.println();
Serial.print("lettera (Ascii value): ");
Serial.print(byteRead);
Serial.print(" ");
if (cmplx)
if (optCount==1 && letterCount<=3)
opt1[letterCount] = byteRead;
// Debug stuff
Serial.print("letterCount: ");
Serial.print("opt1: ");
Serial.print(opt1);
else if (optCount==2 && letterCount<=3)
opt2[letterCount] = byteRead;
// Debug stuff
Serial.print("opt2: ");
Serial.print(opt2);
else if (optCount==3 && letterCount<=2)
opt3[letterCount] = byteRead;
// Debug stuff
Serial.print("opt3: ");
Serial.print(opt3);
letterCount++;
//listen for numbers between 0-9
if(byteRead>47 && byteRead<58)
//number found
if (cmplx)
/* If mySwitch is true, then populate the num1 variable
otherwise populate the num2 variable*/
if(!mySwitch)
num1=(num1*10)+(byteRead-48);
else
num2=(num2*10)+(byteRead-48);
// Counters used to correctly store decimal numbers
counter=counter*10;
numOfDec++;
// Looks for decimal points
if (byteRead==46)
mySwitch=true;
Once the opt1, opt2 and opt3 arrays are correctly populated I can compare them with tags and then call the respective routine.
The problem
I'm pretty close, the code stores the decimal numbers correctly but it doesn't with the arrays. The output I get inserting this string
X,Rol,Con,Kd,1.12,X
is the following:
lettera: 88
virgola numero: 1
lettera: 82 letterCount: 0 opt1: R
lettera: 111 letterCount: 1 opt1: Ro
lettera: 108 letterCount: 2 opt1: Rol
virgola numero: 2
lettera: 67 letterCount: 0 opt2: C
lettera: 111 letterCount: 1 opt2: Co
lettera: 110 letterCount: 2 opt2: Con
virgola numero: 3
lettera: 75 letterCount: 0 opt3: K
lettera: 100 letterCount: 1 opt3: KdX,Rol,Con,Kd,1.12,X <- WTF?
virgola numero: 4
virgola numero: 5
opt1: RolConKdX,Rol,Con,Kd,1.12,X <- WTF?
opt2: ConKdX,Rol,Con,Kd,1.12,X <- WTF?
NUMBER: 1.12
lettera: 88
How to reset arrays of chars quickly and why do I get arrays completely messed up?
