In the following circuit a 120 ohm termination resistor is placed across the Rx+ and Rx- data lines connected to a RS485/422 transceiver. The transceiver is protected up +/- 60V.
I want voltage protection on these lines up to 24V. This would mean a user could possibly connect 24V directly across the 120 ohm resistor resulting in 4.8 Watts power disapation. Safe design practice would be to add at least around 50% tolerance to my resistor meaning a need a resistor rated around 7W.
Based on my searching a 7W resistor means moving to a large through hole part. The board space I have is very limited and this is undesirable.
Is there any alternatives to this problem?
  • \$\begingroup\$ Why not a PTC terminator? \$\endgroup\$ Commented Oct 29, 2014 at 18:34
You could AC-terminate the pair, as described in this application note, but take care to read the caveats.
http://www.ti.com/lit/an/slla070d/slla070d.pdf
@Ignacio's suggestion of using a polyfuse as part of the termination resistor might be a better general solution.
    \$\begingroup\$ The poly fuse is a nice idea...(but I always feel like I'm walking a tight rope when trying to design one in.) Maybe one of those zener polyfuse combo's.. I've used one for an over voltage fault protect and it seemed OK. \$\endgroup\$ Commented Oct 29, 2014 at 19:28
    \$\begingroup\$ Oops.. You'd need two back to back zeners, you don't want to short the signal. :^) \$\endgroup\$ Commented Oct 29, 2014 at 19:38
    \$\begingroup\$ There are Bi directional TVS diodes for such voltages. \$\endgroup\$
    – Lior Bilia
    Commented Oct 30, 2014 at 13:40
  • \$\begingroup\$ @SpehroPefhany I'm a little apprehensive about the limited data speeds but still a helpful answer and thanks for the link to a great reference document. \$\endgroup\$
    – RSmaller
    Commented Oct 30, 2014 at 15:48
