-1
simulate this circuit – Schematic created using CircuitLab How would I solve this circuit using mesh analysis? I can't make a supermesh because I would then have to know the voltage across the independent current source and I can't have 2 meshes because I have a dependent current source.
closed as off-topic by hkBattousai, placeholder, Daniel Grillo, Chetan Bhargava, user17592 Nov 5 '14 at 14:57
  • This question does not appear to be about electronics design within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ By KCL at the top right node \$I_1 = 1\text{A} = 3i_x + i_x = 4i_x\$ so \$i_x = 0.25\$A. \$\endgroup\$ – Null Oct 30 '14 at 14:51
  • \$\begingroup\$ @Null Well that works for this circuit, but if this circuit was part of a larger circuit that had several more meshes you wouldn't be able to solve it using KCL directly. You would have to create the loop currents. So is there a way to solve this by setting up equations involving KVL and loop currents? \$\endgroup\$ – dfg Oct 30 '14 at 14:54
  • 5
    \$\begingroup\$ Homework questions with no attempt at a solution are closed. \$\endgroup\$ – Leon Heller Oct 30 '14 at 15:14
  • \$\begingroup\$ @LeonHeller What do you mean no attempt at a solution? I did attempt it, and what I came up with is in the post... I tried a supermesh and 2 meshes and I listed the problems with that in the post. \$\endgroup\$ – dfg Oct 30 '14 at 15:19
  • \$\begingroup\$ You can do a supermesh, but then you still need to define that supermesh current in terms of the dependent current source as the supermesh current branches into the dependent source and R2. \$\endgroup\$ – EwokNightmares Oct 30 '14 at 16:09
I assume the controlled source is a CCCS.
The left most clockwise mesh current, \$i_a\$ is by inspection \$i_a = 1A\$.
Clearly, the right most clockwise mesh current is just \$i_b = i_x\$. But \$i_b\$ cannot be found by KVL (as you've pointed out) so we need an auxiliary constraint to replace the KVL equation.
That constraint is given by the controlled source:
$$i_a - i_b = 3i_x = 3i_b \Rightarrow i_b = \frac{i_a}{4} = 0.25A = i_x$$
Remarkably, the solution does not depend on the resistor values.
