The code below flashes some LEDs in order: pin 1, pin 2, pin 3, pin 4.
After this sequence has completed I would like to reverse direction and show pin 4, pin 3, pin 2, pin 1.
I wrote the code below but it's not working in reverse order.
What might be wrong?
#include <htc.h>
__CONFIG(1,OSCSDIS & HSPLL);
__CONFIG(2,BORDIS & PWRTDIS &WDTDIS);
__CONFIG(3,CCP2RC1);
__CONFIG(4,LVPDIS & STVREN);
__CONFIG(5,UNPROTECT);
__CONFIG(6,WRTEN);
__CONFIG(7,TRU);
#define _XTAL_FREQ   40000000
void delay_sec(unsigned char seconds)    // This function provides delay in terms of seconds
    unsigned char i,j;
    for(i=0;i<seconds;i++)
        for(j=0;j<100;j++)
            __delay_ms(10);
void led_display(char a)
    switch(a)
        case 0: PORTB=0x01;PORTD=0x08;  break;
        case 1: PORTB=0x02;PORTD=0x04;  break;
        case 2: PORTB=0x04;PORTD=0x02;  break;
        case 3: PORTB=0x08;PORTD=0x01;  break;
void main()
    TRISB=0x00;
    TRISD=0x00;
    char a,b;
    while(1)
        led_display(a);
        a++;
        delay_sec(1);
        if(a==4)
            a--;
You increment a every time and then you decrement it if a == 4. So a equals three in the beginning of you while-loop, then you increment it to four and decrement it, because it equals four. Now it is three again when you jump back to the start of loop.
Try something like:
bool directionForward == true;
while(1) {
    led_display(a);
    delay_sec(1);
    if(directionForward) {
        a++;
        if(a==4) directionForward = false;
    } else {
        a--;
        if(a==0) directionForward = true;
And one other point: Try to avoid using this delay-function. Use a timer interrupt instead.
  • \$\begingroup\$ Your first line uses a comparison operator instead of an assignment operator, which is what I'm sure you meant. Also, I don't think htc has a bool type. I do think it has a bit type, though. Not sure if true and false are built-in. \$\endgroup\$ – Dan Laks Oct 31 '14 at 17:07
As your code currently stands, it will increment a until it reaches 4, then it will decrement it to 3 and then increment it back to 4.
That is, led_display will be called with the following arguments
If I understand you correctly, you would like it to successively increment from 0 until it reaches 3, and then decrement its way down to 0
The way I would implement that is by using a "direction variable", one way of doing so would look like this
TRISB=0x00;
TRISD=0x00;
char a=0, b, dir=1;
while(1)
    led_display(a);
    a+=dir;
    delay_sec(1);
    if(a==3)
        dir=-1;
    else
    if(a==0)
        dir=1;
NOTE: this code is effectively the same as GER_Moki's, just the sequence and the operations are purposely verbose and closer to your original code for clarity
    \$\begingroup\$ Or, even shorter: if (a==3 || a==0) dir = -dir; \$\endgroup\$ – RJR Oct 31 '14 at 8:03
    \$\begingroup\$ I don't like writing magic numbers... Add #define UP 1 and #define DOWN -1 to the code and use it (dir=UP; dir=DOWN). \$\endgroup\$ – GER_Moki Oct 31 '14 at 10:52
  • \$\begingroup\$ Both completely correct comments. I consciously made the decision to keep it simple and aim it directly toward the questioner, who I feel may be not be a confident programmer; if my answer can address the question as simply as possible, then these two additions can only help along any beginning programmer toward mastery. \$\endgroup\$ – Al Longley Oct 31 '14 at 15:55
In addition to what is presented in these other answers, I don't see where the variable a is ever initialized. Since it is a local (on the stack) it is not be guaranteed to be 0 like it would be if it was a global variable.
The code currently reads:
char a,b;
while(1)
    led_display(a);
It should be something like:
char a,b;
a = 0;
while(1)
    led_display(a);
no matter what other changes are made.
