I just saw this question and was wondering how this circuit actually works, since I couldn't really figure it out, I though about asking it.
This is the circuit I am talking about: Circuit
Lets label transistors from left to right as: Q1, Q2, Q3, Q4. I dont really know where to start, how to analyze this circuit to figure it out how it works. What I am especially curious about is the purpose of Q1? Or what about the diode?
If someone could give a detailed description of the circuit I would be really thankfull.
    \$\begingroup\$ electronics.stackexchange.com/questions/135464/… \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 31 '14 at 14:24
  • \$\begingroup\$ I understand the operation of Q1 now, but why would you use it in the first place? Why not tie Input A to the base of Q2? What is the advantage of doing it this way? \$\endgroup\$ – Golaž Oct 31 '14 at 15:01
    \$\begingroup\$ electronics.stackexchange.com/questions/136021/… \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 31 '14 at 15:03
    \$\begingroup\$ What would the appropriate resistor be? The chip designer has little to no control over what the end user connects to the chip, so a reverse-biased diode presents the easiest solution. \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 31 '14 at 15:14
    \$\begingroup\$ @Golaž also, you can get multiple emitter junctions on those transistors, which allows you to use many inputs as "AND" style inputs, it's easier than having lots of diodes instead. Old style inputs to these gates was done by a simple diode, but this way is low input impedance and multiple inputs made easier by a multi-emitter transistor \$\endgroup\$ – KyranF Oct 31 '14 at 15:49
Q1 gets input current and voltage, and operates in "reverse active mode" to make current flow from VCC through the 6K Ohm resistor, through the Base, out the collector(!) and into the base of Q2.
Q2 then turns on, sourcing current in the usual fashion into the base of the output arrangement created by Q3 and Q4. When input A is high, Q2 turns on Q3, which grounds Q4 making the output high impedance, letting an external resistor pull up to VCC or whatever it's connected to.
The collector-emitter in Q4 is able to pull towards GND (perhaps not quite reaching GND though), and this is an "Open collector" style logic set-up, because the top (collector!) of Q4 is the connection to the outside world. You would probably have an external pull up resistor on the output, and when Input A is low, it will pull the output close to GND.
  • \$\begingroup\$ Q3 and Q4 do not form a Darlington pair. \$\endgroup\$ – Matt Young Oct 31 '14 at 14:45
  • \$\begingroup\$ @MattYoung ah, yes I see that the collectors are not tied together. by mad. changing now \$\endgroup\$ – KyranF Oct 31 '14 at 15:03
    \$\begingroup\$ @Golaž my guess is for current limiting, and threshold/voltage input hysteresis. VCC also needs to be a certain voltage for this to work, as there is a 1.1/4.5 ratio for the base-emitter voltage for Q3 here. This means to ensure turn-on at 0.7V the VCC rail must be above ~3V. \$\endgroup\$ – KyranF Oct 31 '14 at 15:28
    \$\begingroup\$ It is merely a clamping diode which limits negative input voltages to only 1 diode drop. It doesnt' affect normal behaviour. \$\endgroup\$ – KyranF Oct 31 '14 at 15:46
    \$\begingroup\$ @Golaž The reason for using a transistor Q1 at the input (TTL) rather than a diode (DTL) which would also provide an appropriate voltage drop is to quickly discharge the base capacitance of Q2 during the high-to-low transition when teh transistor goes into forward active mode briefly. Without the transistor, the buffer would not switch 'off' as quickly. \$\endgroup\$ – Spehro Pefhany Oct 31 '14 at 16:49
