I designed a Buck converter which drives several LEDs. The PWM signal, which has a certain fixed duty cycle, is generated by a 555 timer IC. The circuit which drives the Buck MOSFET, including the 555, is boot-strapped and floating between 0V and 310V (rectified 220V AC). A current sensor measures the LED current and is supposed to send a pulse to the reset pin of the 555 to delay the next pulse.
The problem is, I can't find a cheap optocoupler which is guarantied to respond in less than one period of the PWM. If the current is not stopped within one period, the current through the Buck inductor would rise above the critical limit and damage the LEDs.
I decided to use a capacitor for isolation. I built up the circuit below to simulate it. However, I couldn't get a good response out of it regardless of what I tried. I would like to know if this method would actually work in theory and application. If it can work, what am I doing wrong here? And also, I would like to see if there is an example design.
