I've wired simple circuit with 9V battery, red LED, 10K resistor to turn the light on.
And I'd like to know if the LED is lighting or not using arduino.
I simply wired Arduino's A0 pin and LED's + lead. Next, if I get value from A0 using analogRead() function, it returns 0 always. If I just read from A0 without wire, it returns random values(I don't know it's random or not, anyway, it seems to be irregular).
Question: How can I know external circuit's LED is lighting or not using Arduino?
PLUS
the question is related with this question
I've tested following schematic(sorry for its poor drawing)
4 digits display ----- 4N35(PIN 1)
           ㄴ---------- 4N35(PIN 2)
ARDUINO 5V ----------- 4N35(PIN 5)
        GND ---------- 4N35(PIN 4)
        A0 ----------- 4N35(PIN 4) <--- This is the goal
If I place LEDs for each side, it works well.
The problem is, the voltage I've measure from 4 digits display is too low as around 0.14. So, it may be the reason 4N35 doesn't emit any signal I think(If I turned the power on of portable range, Arduino side LED is turned on for a moment).
Okay, Question again please !!! I'd like to know the state of portable range and my trying is figuring out which LED is lighting from the 4 digits display. But, 4N35 could not catch its voltage(not sure tho). How can I do this? Any comment will be helpful.
4 digits display with 6 pins portable range portable range control part portable range control part 2
  • \$\begingroup\$ Can you add schematic for clarification? \$\endgroup\$ Nov 8, 2014 at 0:59
I am assuming you are going to simply measure the voltage drop across the LED and use that to determine if the LED is on, this will work but you will need a couple of extra components, you can damage your arduino if you feed in a voltage over 5V.
In the above R1 and R2 form a voltage divider to reduce the voltage on the A0 pin of your arduino. We can calculate the maximum voltage you can use to safely stay under 5V on A0:
Vmax = 5.0 / (R2 / (R1 + R2))
     = 5.0 / (47000 / (100000 + 47000))
     = 15.6V
Finally read the value of A0 in your arduino code and use the following formula to convert that value into a voltage:
float r1 = 100000;
float r2 = 47000;
float vRaw = (analogRead(0) * 5.0) / 1024.0;
float vDrop = vRaw / (r2 / (r1 + r2));
Depending on the accuracy needed you may need to mess with the 5V value above and adjust r1/r2 to a measured value (depending on accuracy of the resistors you are using).
For a complete example see https://www.udemy.com/blog/arduino-voltmeter/
  • \$\begingroup\$ wont the value read at A0 will always be the same? Since V+ is referred? \$\endgroup\$
    – User323693
    Aug 4, 2016 at 12:27
You could use a photoresistor.
           PhotoR     10K
 +5    o---/\/\/--.--/\/\/---o GND
 Pin 0 o-----------
http://playground.arduino.cc/Learning/PhotoResistor
  • \$\begingroup\$ okay, but, what if there're pretty many LEDs and they're very close each other? how can I get which LED is lighting? \$\endgroup\$ Nov 6, 2014 at 3:19
  • \$\begingroup\$ If they're on the same wire, if one lights the others should too.. \$\endgroup\$
    – hanoo
    Nov 6, 2014 at 3:23
  • \$\begingroup\$ You can mesure the voltage of the circuit using a voltage divider to know if the battery is good enouth. \$\endgroup\$
    – hanoo
    Nov 6, 2014 at 3:25
