I had a working circuit with Wiznet W5100, but to get better performance I switched over to Wiznet W5200 (in Wiz820io module). This involved rewiring the pins, changing the register address and also the Read/Write code for the ethernet module as this chip supports Burst Write.
Datasheet here
However (this has me totally stumped), when I power on the circuit and read the registers that I have just written to (GATEWAY, IP etc), all I get is 0x00.
This is what I got using logic analyzer
The MISO line is just flat. No data being sent back to the master.
These are my read/write routines for the Ethernet module :
//OP CODES (TO BE OR'ED WITH UPPER 7 BITS OF ADDRESS)
#define W5200_WRITE             0x80
#define W5200_READ              0x00
//BURST WRITING FOR W5200. FOR DATA LENGTH = 1, DEFAULTS TO BYTE WRITE
void ETHERNET_WRITE(uint16_t address, uint8_t *data, uint16_t len)
    W5200_SS_LOW;       //SET W5200 SS LOW
    SPI_TXRX((address & 0xFF00)>>8); //WRITE HIGH BYTE OF 2 BYTE ADDRESS
    while(SPI_DATA_RECEIVED==0);
    SPI_TXRX((address & 0x00FF)); //WRITE LOW BYTE OF 2 BYTE ADDRESS
    SPI_TXRX(W5200_WRITE | ((len & 0x7F00)>>8));    //WRITE OPCODE | DATA LENGTH (UPPER 7 BITS)
    SPI_TXRX(len & 0x00FF); //DATA LENGTH (LOWER 8 BITS)
    for(uint16_t i=0; i<len; i++)
        SPI_TXRX(data[i]); //WRITE DATA
    W5200_SS_HIGH; //TURN BACK SS HIGH
//BURST READING FOR W5200. FOR DATA LENGTH = 1, DEFAULTS TO BYTE READ
void ETHERNET_READ(uint16_t address, uint8_t len, uint8_t* retval)
    SPI_TXRX(address & 0x00FF); //WRITE LOW BYTE OF 2 BYTE ADDRESS
    SPI_TXRX(W5200_READ | ((len & 0x7F00)>>8)); //READ OPCODE | DATA LENGTH (UPPER 7 BITS)
    for(uint8_t i=0; i<len; i++)
        SPI_TXRX(0x00); //WRITE DUMMY DATA TO READ DATA
        retval[i] = SPI_RX_DATA;
    W5200_SS_HIGH;  //SET SS HIGH
Initially I was powering this module using LM2950 33, but since it's max current output is 100mA, I moved over to LM317 adjustable LDO that is now powering the module with 3.14V
This is my ethernet intialization code
void ETHERNET_INIT(uint16_t ip_address, uint16_t subnet_address, uint16_t gateway_address, uint16_t mac)
    uint8_t val[6];
    uint8_t retval[6];
    uint8_t i;
    W5200_RESET_LOW;
    _delay_us(50);
    W5200_RESET_HIGH;
    for(i=0;i<20; i++)
        _delay_ms(20);
    val[0] = MR_RST;
    ETHERNET_WRITE(MR, val,1);
    ETHERNET_READ(MR, 1, retval);
    while(retval[0] !=0) {ETHERNET_READ(MR, 1, retval);}
    printf("*** Ethernet ****\r");
    //if(ETHERNET_DEBUG)
        printf("Reading MR : %u\r", retval[0]);
    //set IP Address
    EEPROM_READ(ip_address, 4, retval);
    ETHERNET_WRITE(SIPR, retval, 4);
        ETHERNET_READ(SIPR, 4, retval);
        printf("IP Address : %u.%u.%u.%u\r",retval[0],retval[1],retval[2],retval[3]);
    //set subnet mask
    EEPROM_READ(subnet_address, 4, retval);
    ETHERNET_WRITE(SUBR, retval, 4);
        ETHERNET_READ(SUBR, 4, retval);
        printf("Subnet Mask : %u.%u.%u.%u\r",retval[0],retval[1],retval[2],retval[3]);
    //set gateway address
    EEPROM_READ(gateway_address, 4, retval);
    ETHERNET_WRITE(GWR, retval, 4);
        ETHERNET_READ(GWR, 4, retval);
        printf("Gateway ip Address : %u.%u.%u.%u\r",retval[0],retval[1],retval[2],retval[3]);
    //set mac address
    EEPROM_READ(mac, 6, retval);
    ETHERNET_WRITE(SHAR, retval, 6);
        ETHERNET_READ(SHAR, 6, retval);
        printf("mac Address : %02X.%02X.%02X.%02X.%02X.%02X\r",retval[0],retval[1],retval[2],retval[3],retval[4],retval[5]);
    //set interrupt high time
    val[0] = 1;
    ETHERNET_WRITE(INTLEVEL, val, 1);
    //set TX and RX memory to 2KB per socket
    //val[0] = 0x55;
    //ETHERNET_WRITE(RMSR, val, 1);
    //ETHERNET_WRITE(TMSR, val, 1);
    //set TX = 8Kb RX = 8Kb for Sock 0 & Sock 1
    val[0] = 0x08;
    ETHERNET_WRITE(SOCKET_0_REGISTER_BASE + SN_RX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_0_REGISTER_BASE + SN_TX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_1_REGISTER_BASE + SN_RX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_1_REGISTER_BASE + SN_TX_MEMSIZE, val, 1);
    val[0] = 0x00;
    ETHERNET_WRITE(SOCKET_2_REGISTER_BASE + SN_RX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_2_REGISTER_BASE + SN_TX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_3_REGISTER_BASE + SN_RX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_3_REGISTER_BASE + SN_TX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_4_REGISTER_BASE + SN_RX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_4_REGISTER_BASE + SN_TX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_5_REGISTER_BASE + SN_RX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_5_REGISTER_BASE + SN_TX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_6_REGISTER_BASE + SN_RX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_6_REGISTER_BASE + SN_TX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_7_REGISTER_BASE + SN_RX_MEMSIZE, val, 1);
    ETHERNET_WRITE(SOCKET_7_REGISTER_BASE + SN_TX_MEMSIZE, val, 1);
    //set RTR - retry time value register for timeout @ 2000us
    val[0] = 0x07;
    val[1] = 0xD0;
    ETHERNET_WRITE(RTR, val, 2);
        ETHERNET_READ(RTR, 2, retval);
        printf("rtr : %x:%x\r", retval[0], retval[1]);
    //set RCR - max retry count to 8
    val[0] = 0x08;
    ETHERNET_WRITE(RCR, val, 1);
        ETHERNET_READ(RCR, 1, retval);
        printf("rcr : %u\r", retval[0]);
    //enable mask for socket 1 interrupt
    val[0] = IMR_S1_INT;
    ETHERNET_WRITE(IMR, val, 1);
    if(ETHERNET_DEBUG)
        ETHERNET_READ(IMR, 1, retval);
        printf("IMR : 0x%x\r",retval[0]);
Any ideas?
  • \$\begingroup\$ Schematic, datasheet, picture, double check solder joints, seems that the MISO output is not idling HIGH so perhaps it's shorted. Do continuity test of the MISO pin to GND. \$\endgroup\$ – KyranF Nov 6 '14 at 12:33
  • \$\begingroup\$ @KyranF I did the continuity test and I could not find a path from MISO to ground. As a test I disconnected the modules pin from its socket (so it's not connected to my circuit) and attached the logic analyzer lead directly to it. The results were the same \$\endgroup\$ – Ankit Nov 6 '14 at 13:00
  • \$\begingroup\$ Does the Wiz module have any handy status LEDs or output communications/alternative method of communicating with it to see if it's working at all? Does it show any signs of life? \$\endgroup\$ – KyranF Nov 6 '14 at 13:24
  • \$\begingroup\$ @KyranF No lights nothing. I tried with another unit and I get blinking lights on the RJ45 jack. It seems like it's trying to establish a link but never does. The lights just keep on blinking. \$\endgroup\$ – Ankit Nov 11 '14 at 14:30
  • \$\begingroup\$ so the Ethernet is trying to detect activity with this other unit, what does the MISO line look like and the software return register values? \$\endgroup\$ – KyranF Nov 12 '14 at 5:17
It's working now. It was the Reset line going from my AVR to the W5200 module. It was never going down to 0V, hence the unit was never getting resetted.
Not sure how I managed to screw up the i/o pin. Connecting the reset line to a different pin on the AVR solved the issue.
| improve this answer | |
