I know the exact values depend on the specific battery used, but is there a general rule for the maximum charge current (as a function of the battery capacity) for each of the mainstream battery technologies (NiCd, NiMH, Li-ion, Li-Polymer, lead-acid), for normal and fast charging? The typical capacity I'm going to use is 10 - 40 Ah.
I don't think so. It depends on a number of factors besides the chemistry, including:
  • what charge algorithm is being used
  • voltage accuracy of the charger (to prevent overvoltage on each cell)
  • temperature sensing ability (faster charge = potential to overheat individual cells)
  • # of cells in series (more cells in series = harder to keep cells balanced and charged safely)
  • manufacturer tradeoffs
This last point is important: maximum charge current is very highly dependent on how the manufacturer has made tradeoffs for energy density vs. power density vs. cycle life. Battery manufacturers such as Sanyo and Panasonic will often sell several different types of batteries, some with high power density, some with high energy density.
As a general rule of thumb, C/10-C/5 is probably safe for most chemistries without taking any precautions. Beyond that, you have to manage the temperature and voltage of the cells carefully in order to implement fast charging in the 1C / 2C / 5C / 10C range. 10C is iffy and I'd be surprised to see any battery of any type that could be charged at higher currents without sacrificing cycle life and safety.
  • \$\begingroup\$ So there's some freedom in trading between charging time, charger complexity and cycle lift. Good info, thanks! \$\endgroup\$
    – Remy Blank
    May 5, 2011 at 22:12
This site has a whealth of battery information - including some indication of charge time: http://www.batteryspace.com/batteryknowledge.aspx.
Interestingly, although load is specified in Amps, a charge indication is given in hours, not amps. I guess that has to do that larger batteries (im Ah) will generally allow for higher charge current - charge time therefore staying constant.
    \$\begingroup\$ The charge current is usually given in "C", meaning a factor of the capacity in Ah. So a charge time of 1h corresponds to a charge current of 1C. Excellent link, thanks! \$\endgroup\$
    – Remy Blank
    May 2, 2011 at 13:55
