I want to create Led PWM controller and I tought it is easy but one line in my code generates more warnings than all my previous little projects. Here is the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity pwmLed is
generic( N : integer := 4
port( pwm : in std_logic_vector(N-1 downto 0);
clk : in std_logic;
leds : out std_logic_vector(7 downto 0)
end pwmLed;
architecture Behavioral of pwmLed is
constant CLOCK_CYCLES : integer := 1000;
signal counter : integer ;
begin
process(clk)
begin
if counter > CLOCK_CYCLES then
counter <= 0;
elsif (clk'event and clk = '1') then
counter <= counter + 1;
end if;
end process;
leds <= "11111111" when counter < (to_integer(unsigned(pwm))/(2**N) * CLOCK_CYCLES) else "00000000";
end Behavioral;
The problematic line is :
All the warnings:
WARNING:HDLCompiler:92 - "E:\Xilinx\Projects\PWM_LED\pwmLed.vhd" Line 48: counter should be on the sensitivity list of the process
WARNING:Xst:647 - Input is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
WARNING:Xst:3002 - This design contains one or more registers/latches that are directly incompatible with the Spartan6 architecture. The two primary causes of this is either a register or latch described with both an asynchronous set and asynchronous reset, or a register or latch described with an asynchronous set or reset which however has an initialization value of the opposite polarity (i.e. asynchronous reset with an initialization value of 1).
WARNING:Xst:1426 - The value init of the FF/Latch counter_31_LD hinder the constant cleaning in the block pwmLed. You should achieve better results by setting this init to 0.
WARNING:Par:288 - The signal pwm<0>_IBUF has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal pwm<1>_IBUF has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal pwm<2>_IBUF has no load. PAR will not attempt to route this signal.
WARNING:Par:288 - The signal pwm<3>_IBUF has no load. PAR will not attempt to route this signal.
WARNING:Par:283 - There are 4 loadless signals in this design. This design will cause Bitgen to issue DRC warnings.
WARNING:PhysDesignRules:372 - Gated clock. Clock net counter[31]_GND_4_o_LessThan_1_o is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop.
I understand them but I got no idea why they occur. I use pwm explicitly so why the warning that this input is never used.
