I am looking for a particular type of spring-loaded knob, similar to the thumb wheel you would find on an old Blackberry - but I cannot seem to find an appropriate name to track one down.
I'd like to be able to turn the knob clockwise or counterclockwise to generate a voltage proportional to the angular displacement, then as soon as you release the knob it would be restored back to its "home" position.
I suppose I could approximate one by attaching a torsional spring to a potentiometer, but I figured this has to already exist.
Thanks.
Very often it is just a simple potentiometer. The spring loading is done in the front panel knob, and that is more often than not a custom designed part.
There are "sprung shaft potentiometers" available, but they are wildly expensive.
The same sort of thing is used on tape and film machines to move the medium back and forth for editing, variously called "shuttle knob" or "jog dial".
