Is there any way I could emulate input into chip using the free emulator, when debugging my code to see if it responds correctly into input?
  • \$\begingroup\$ Are you talking about simulating input on the I/O ports? \$\endgroup\$ – user17592 Nov 10 '14 at 19:41
    \$\begingroup\$ You should really consult the documentation. \$\endgroup\$ – Matt Young Nov 10 '14 at 19:49
  • \$\begingroup\$ Can you direct me to the right part of that documentation, because I couldn't find anything related to this when I read that yesterday... \$\endgroup\$ – The amateur programmer Nov 11 '14 at 5:30
  • \$\begingroup\$ @CamilStaps yes and analog signal input too. \$\endgroup\$ – The amateur programmer Nov 11 '14 at 5:31
  • \$\begingroup\$ See here: youtube.com/watch?v=4gzeR4YnMFY \$\endgroup\$ – user17592 Nov 11 '14 at 13:57
Yes, there definitely is. A fairly elaborate system has been in MPLAB for a long time, including in version 8. However, the full details weren't documented until recently. Only a stripped down set of capbilities via a clickety-click GUI were available.
| improve this answer | |
  • \$\begingroup\$ Can you specify how can I use that to debug my program? Haven't found it yet. \$\endgroup\$ – The amateur programmer Nov 10 '14 at 19:31
    \$\begingroup\$ @Theam: Yes, I probably can. \$\endgroup\$ – Olin Lathrop Nov 10 '14 at 19:33
  • \$\begingroup\$ Thanks can you update that into your answer please. Can't wait to try it out. :D \$\endgroup\$ – The amateur programmer Nov 10 '14 at 19:34
    \$\begingroup\$ @Theam: Yes I could. But, this is getting tiring. I answer your questions, then you keep coming back with more unrelated questions. \$\endgroup\$ – Olin Lathrop Nov 10 '14 at 19:35
