I cant communicate with the Atmega328p. I've flashed fuses low: 0x59, high: 0xD9 and changed wiring. Now I've connected 16Mhz crystal to the XTAL1, XTAL2 pins, and 2x22pF to the crystal. But I can't read/write from/to the chip. How can I recover my avr? Is it possible?
My chip is Atmega328p.
  • \$\begingroup\$ Have you tried the lowest baudrate for programming? \$\endgroup\$ – ChThy Nov 15 '14 at 17:48
  • \$\begingroup\$ Yes. But this does not fix the problem. \$\endgroup\$ – Edward Nov 15 '14 at 22:16
I found the problem. Problem was with fuses. Mentioned fuse settings require a 8Mhz crystal, not 16. So I've attachd external 8Mhz crystal, then changed fuses to use with 16Mhz.
