I want to program that specific microcontroller (MSP430F2274) and i would like to hear your opinion on what programmer to choose . I prefer one that can be used with a linux machine.
So what you suggest me ?
Thank you.
The MSP430 can be programmed with either four-wire JTAG or a two-wire TI-specific variant called Spy-Bi-Wire. The official programmer-debugger is called the MSP-FET, which supports both four-wire JTAG and Spy-Bi-Wire. If this is for commercial development, you probably want to use this programmer.
For production purposes, TI sells the MSP-GANG 8-controller in-circuit gang programmer.
If you're just a hobbyist, however, the MSP430 can be programmed (Spy-Bi-Wire only) using the MSP430 Launchpad dev kit. DIP package versions can be plugged into the board for programming. For SMT versions, break the Spy-By-Wire pins out to a header on your PCB and make a cable so you can make the appropriate connections to the Launchpad. I've done this with a couple of boards and it is fairly effective.
Look at the "DRIVERS" section in the mspdebug manual for the full list.
The cheapest option is probably the Launchpad board, and it is already connected to a target, so you can do a simple LED-blink example to get started and prove that the tools are set up properly. Then break out the SBW lines to your msp430f2274 target.
On Ubuntu, you can "sudo apt-get install gcc-msp430 mspdebug" and have a working toolchain.
