I have a combinational circuit and I would like to find its critical path in design compiler. Essentially, I want to find out by how much the combinational logic will reduce the maximum clock frequency of the larger sequential design.
For this purpose, I have added registers along the input of the combinational circuit (a simple multiplier in this case) which are clocked on the rising edge of a clock as advised in How to find the critical path delay of a big combinational block. I then run create_clock clk -period 5 -name clk
and report_qor
in DC, but I'm getting a Critical Path Length of 0.00 ns. This looks odd. If I move the multiplier directly to the test module, I get a more reasonable-looking Critical Path Length of 4.88 ns however.
module my_multiplier(
output reg [31:0] out,
input [15:0] in1, in2,
input enable
always @(*) begin
if (enable) begin
out = in1 * in2;
end
end
endmodule
I've created a separate module to instantiate the multiplier circuit and also clock the inputs to the multiplier:
module Test_multiplier_Tcrit(
output [31:0] out,
input clk, enable
reg [15:0] in1_reg, in2_reg;
my_multiplier my_multiplier(.out(out), .in1(in1_reg), .in2(in2_reg), .enable(enable));
always @(posedge clk) begin
in1_reg <= in1;
in2_reg <= in2;
end
endmodule
