Is it true that a modem (such as a 3G dongle) will use more power when signal strength is weak that when signal strength is strong? Also, can someone link me to a resource that discusses this? What is the variation in power usage between weak and strong signal for an average modem?
Indeed, GSM devices in general change their transmission power when receiving a weak signal. The technique is called transmission power control, or just power control.
I'm also 99% sure that they change the amplification of the receiver.
Note that when receiving or making a call, the transmitter will start at higher power, to lower it afterwards when the connession is established. That's why some people advocate waiting a second before taking it to the ear.
  • \$\begingroup\$ Note that in G3 this power control is adapted lots of times per second based on the timining to the base station. \$\endgroup\$
    – PlasmaHH
    Commented Nov 14, 2014 at 9:26
