I have bought an SIM900A Mini V4 GSM module. Here is the module, enter image description here
I want to configure with arduino to send and receive SMS.
Do I have to connect TXD of this module--Tx of Arduino & RXD of this module--Rx of Arduino or other way around?
There is no datasheet or documents on this new module.
When I search about RXD & TXD, I found this in enter link description here
TxD means "Data to be transmitted over the comms link" - which will clearly be an input to the modem; Similarly, RxD means "Data that has been received from the comms link" - which will clearly be an output from the modem.
But I couldn't send or receive SMS using this configurations.
As I am new to this, It would be very helpful if anyone help on this.
Thank you in advance.
I have a very similar board that is on the photo you posted, but with SIM900A instead of SIM900.
You can't connect the RS232 Serial Port directly to Arduino because of mismatch in voltage. The voltage on these pins is higher than Arduino's 5V. You would need a TTL to RS232 converter to hook up Arduino to those pins.
This board has also another interface to communicate. Those 2 jumpers can be removed and then you have access to 2.8V serial pins. Looking at your photo - there are 6 of them, the bottom 2 are GND, and the top 2 are RX (the one on the left) and TX (the one on the right). The bad news is you also can't directly connect Arduino to these pins. You would need a logic level shifter to shift 5V to 2.8V. I've however used a bluetooth-to-serial module from ebay that outputs 3.3V and risked connecting it to these pins. It works smoothly.
The picture was wrong. I checked it so many times but can not do it. I want to show you the way to communicate from Arduino board with SIM900A Mini.
Arduino uno |  SIM900A mini
+5V         |   +VCC   (recomment used to power supply out)
GND         |   GND
Pin 2 (RX)  |  5VT (nearly power port +5V)
Pin 3 (TX)  |  5VR (nearly port port +5V)
Good luck!
  • \$\begingroup\$ This question already has an accepted answer which appears to provide the correct solution. \$\endgroup\$ – David Jan 17 '15 at 16:37
  • \$\begingroup\$ Yes Jim. It's perfectly works this way also. \$\endgroup\$ – Jeyanth90 Jan 18 '15 at 17:35
protected by Nick Alexeev Jan 26 '15 at 18:08
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
