I am using Eagle5.11 to prepare schematic diagram. I need the .lbr file for enter image description hereenter image description here
Breakaway-Male Header,CAT9532 SOIC 28 pin package..
So where can i find a bulk of .lbr files for these small but necessary components?
What other .lbr's you would suggest for a guy preparing schematics for his projects that includes things like interfacing pic mcu(16f/32mx) with driver ic's(uln2003) and lots of sensors?
I got one from sparkfun but that doesnt contain what I am looking for
Thanks in advance..
    \$\begingroup\$ The default libraries have most of these devices already available. Check ref-packages.lbr for footprints. \$\endgroup\$ May 5, 2011 at 21:19
The microbuilder library http://www.microbuilder.eu/Projects/EagleFootprintLibrary.aspx is pretty good and is maintained by the all around nice guy Kevin Townsend. There is also the adafruit library https://github.com/adafruit/Adafruit-Eagle-Library
That said, it would probably take no more than 5 minutes to draw that 100 mil header. In my experience Eagle footprints, even the standard ones, are of varying quality and it pays to learn to draw your own.
