FPGA beginner here.
I have a Basys2 FPGA board(i code in verilog) and i wish to make it communicate with my PC. Currently it receives data from a slave device and stores it in an 64 bit register. However i want to send this data to my computer for processing, and process it in matlab.
I have done some research. It seems like i can either use EPP API of digilent or just use UART communication.[: seems like this is out of option now, since i don't have access to a UART translator]. However i can't find any explanatory enough examples about any of the methods. Existing examples seem to have a bunch of code "that just works". But lack of explanation makes me unable to adapt it for my
For example there is DeppGetReg(HIF hif, BYTE bAddr, BYTE* pbData, BOOL fOverlap) function on the API but i don't know what to input(specificly the address) to provide to it to read values from FPGA.Only document i could find was in this link. I am clueless on UART too.
Here are the available I/O ports of FPGA. The only USB port is used for programming the FPGA, not sure if i can also have communication via that port.
I would appreciate if you can give any ideas on where to start considering my FPGA board. Thanks in advance.
