I'm using MPLAB X IDE with XC8 compiler and I would like to create a menu system to a GLCD module, but I'm having trouble initializing my MainMenuItemsList[] array. I'm not getting error on compliling but if I'm debugging the project, I can see that only the first item is initialized. What can be the cause?
Here is the relevant code fragment:
typedef struct menuitem
  char ItemName[10];
  void (*handler)(void);
  struct menu *ChildSubMenu;
}MenuItem;
typedef struct menu
  char MenuName[10];
  char NumberItems;
  //struct menu *ParentMenu;
  MenuItem *Items[12];
}Menu;
MenuItem MainMenuItemsList[12] = {  {"SubMenu1", NULL, NULL},
                                    {"SubMenu2", NULL, NULL},
                                    {"SubMenu3", NULL, NULL},
                                    {"SubMenu4", NULL, NULL},
                                    {"SubMenu5", NULL, NULL},
                                    {"SubMenu6", NULL, NULL},
                                    {"SubMenu7", NULL, NULL},
                                    {"SubMenu8", NULL, NULL},
                                    {"SubMenu9", NULL, NULL},
                                    {"SubMenu10", NULL, NULL},
                                    {"SubMenu11", NULL, NULL},
Menu MainMenu = {"MainMenu",12,&MainMenuItemsList};
  • \$\begingroup\$ How do you know that the array is not being initialized correctly? Did you tested on an actual LCD? Some of the later versions of MPLAB X are not displaying the correct values on the watch window. \$\endgroup\$ Nov 16, 2014 at 1:18
  • \$\begingroup\$ Yes I've tested it. The strings "MainMenu" and "SubMenu1" are written correctly on the LCD but the other arrays ItemName[10] are full of null characters instead of SubMenu2...11. (By the way I'm using MPLAB X v2.15) \$\endgroup\$
    – John
    Nov 16, 2014 at 1:40
  • \$\begingroup\$ It wont function because I need a list of structs, from that I select the first member and write the name of it (SubMenu1) to the screen than I choose the second element etc. That appears in my code like this: void drawMenu(Menu *menuToShow, unsigned char selectedIndex) { ... glcd_puts(menuToShow->Items[i]->ItemName,8,i+1,0,1,-2); ... } And the call of the function: drawMenu(&MainMenu, 0); Sorry but I don't know how to format the code block properly, but I tried it for several times. \$\endgroup\$
    – John
    Nov 16, 2014 at 13:48
  • \$\begingroup\$ Does nobody have an idea? I've tried this too, but it didn't worked. link \$\endgroup\$
    – John
    Nov 20, 2014 at 18:45
when you define MenuItem *Items[12]; you are creating an array of addresses, not an address to an array of structs (which is what you want).
take the "[12]" out:
typedef struct menu
  char MenuName[10];
  char NumberItems;
  MenuItem * Items;
}Menu;
