I have an issue with Proteus Isis.
The image below illustrates the problem. I can't see the values of a struct's fields and I think that Proteus can't see the struct too.
Full Resolution
Anyone know how to deal with this?
If your debug files are COFF format, please check this link: http://support.labcenter.co.uk/forums/viewtopic.php?f=9&t=3770&p=12623&hilit=+dt_float+#p12623
Double click on the MCU in the ISIS workspace to brings up the edit component window. In the "other properties" edit box, add DT_FLOAT=MICROCHIP_BIGENDIAN
  • \$\begingroup\$ I have not found that option. Is it in Proteus? \$\endgroup\$
    – user49894
    Nov 17, 2014 at 11:48
  • \$\begingroup\$ Just in your workspace, on your PIC MCU. \$\endgroup\$
    – diverger
    Nov 17, 2014 at 11:52
  • \$\begingroup\$ You should create a new properties, DT_FLOAT \$\endgroup\$
    – diverger
    Nov 17, 2014 at 11:57
  • \$\begingroup\$ Sorry. I didn't see the last paragraph of your answer. Was edited? \$\endgroup\$
    – user49894
    Nov 17, 2014 at 12:28
