I am having a problem creating a cable to connect with two devices. The first devisce is an Intellivue MP70 that I want to connect to the RS232 port using an RJ45 end. On the other side there should also be a RJ45 connection that should be connected to a Lantronix EDS-MD Server, and i can't figure out the pin assignment.
I got the following image:
And the following table:
However, as you can see this is a connection from RJ45 to DB9. How do I translate this so i get RJ45 on both ends of the cable?
I can also mention that I have access to a RJ45 to Screw terminal adaptor on one side.
  • 5
    \$\begingroup\$ You'll really need to mention what's on the other side of the cable, it seems you know the Intellivue side of things but there are a lot of different schemes for RS232 to RJ45. \$\endgroup\$
    – PeterJ
    Nov 19, 2014 at 11:23
You can remap the DB9 to the RJ45 of your Lantronix EDS-MD. i have found a adapter 'pin out' in the user manual.
there are Adapters and Serial Port Pinouts listet - in the overview there is one cable described as
500-153- RJ45-to DB9F
Connects the RJ45 RS232 serial port s of EDS-MD to a DB9M DTE interface of a PC or serial device to check that serial ports in the EDS- MD are functioning properly.
but this one has no drawing.. so i looked at the rest and searched for the 'DB9M DTE'
200.2070A Adapter RJ45-to- DB9F
Allows a standard straight-pinned CA T5 cable to connect the EDS-MD to the DB9M DTE interface of a PC or serial device.
for this is a drawing on page 96: http://www.lantronix.com/pdf/EDS-MD_UG.pdf#page=96&zoom=auto,-169,21
the only problem is there is no direct naming of the signals. but i think you can use the DB9 Pinout to match your mentioned DB9.
So your table would be as following:
DB9 List from Wikipedia
(http://de.wikipedia.org/wiki/RS-232#Verkabelung_und_Stecker)
DTE – data terminal equipment
DCE – data circuit-terminating equipment
Name is seen from DTE site.
DTE                     ---------------------->  DCE
RJ45 Lantronix EDS-MD   -   DB9  Name     -    RJ45 Intellivue
                        -   -    PG       -
      6                 -   3    TxD      -      7
      3                 -   2    RxD      -      5
      8                 -   7    RTS      -
      1                 -   8    CTS      -
      2                 -   6    DSR      -
      4&5               -   5    GND      -      4
      2                 -   1    DCD      -
      7                 -   4    DTR      -
                        -   9    RI       -
pleas check again - eventually you have to exchange TxD & RxD on one site...
