So I've used the popular linear regulators (7805, LM317, LD1117, etc), but I'd like to learn more about switching regulators.
Are there any "must have" switching regulators out there that are as popular, as ubiquitous as those common linear ones?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThat's easy, MC34063 is a very common part that has been around for quite a while so there are several manufacturers and many applications.
In the buck configuration it will output up to 700 mA without dissipating very much power.
It comes in dip8 and soic8, so it's small enough for many products and still easy to prototype with.
You can find lots on ebay for very little money
The only disadvantage is that it's an older part with a lower switch frequency than newer parts, so the inductor will have to be a bit larger.
For space-critical applications you will probably need a newer part with a higher switching frequency, so the inductor can be smaller, but those parts are quite a bit more expensive.
With an external switch transistor you can get higher currents.
The MC34063 is so popular there's even a Youtube video about it.
For switchers there are no regulators iconic like the LM78xx is for linear.
The big advantage of switchers is of course their efficiency, and that's only optimal under certain conditions, like input voltage/output voltage ratio, switching frequency and output current. And while most linear regulators use more or less the same working principle,switching regulators exist in different topologies, like buck, boost, buck/boost and flyback.
That's why there's such a wide range of switchers available and why leading manufacturers like Linear Technology have parametric search on their webpage to help you find the right part for a specific job. And even then the search may give you more than a dozen hits. If you feel you're losing your way, call your supplier's FAE.
There are no "must have" switching regulators, a.la. the 78xx or LM317.
For the "electronics hobbyist" I recommend looking at Linear Tech's switching regulators. They are slightly more expensive than others, but that doesn't matter so much when just buying a few. Also, they have an awesome simulator, LTSpice, that makes it much easier to get something up and running on your first try-- and they have an example circuit/simulation for just about every chip they make.
Consider the PoL (Point of Load) Alliance parts. Multiple sourced, includes inductors in the part so about as easy to use as a linear regulator. Parts with crosses here from MuRata.
Switchers are usually designed for a specific application. National Semiconductor has this on-line software for their Simple Switcher devices that helps one select a suitable device, and designs a supply using it. They also have modules that are very easy to use.
The 78SR series is relatively new, but since it's a drop-in replacement for the 78xx series, it's got good potential to become what you're asking about.
