I have a very limited understanding of how current works in parallel or in series. I am trying to connect a pair of LEDs to a constant current power supply (1200ma) in which the power supply automatically adjusts the output voltage according to the current draw.
Which (if any) will result in a brighter output? Series or parallel configuration?
The LEDs are Cree XP-G2 1A R5 that can handle 1.5A of current. Of course I don't want to max this out because it will create too much heat. I have tried both setups and measured the amp draw maxed at 1200ma but I can't tell which is brighter. Does it even matter in my case?
Any help would be greatly appreciated.
You should connect them in series because:
  • if diodes are connected in series - exactly the same current is flowing
  • current will be 1200mA, because it does not split like in parallel
In series - circuit will need higher voltage to reach 1200mA on these leds, because in series voltage (not current) splits.
Series connected since power supply voltage is adjustable but current source has 1200 mA limit. To draw current required by two series connected LED voltage needs to be increased.
