I have successfully interfaced to my winbond chip via the bus pirate. I have successfully executed the chip identifier command and chip erase commands via spi, i would like to read and delete the chips security registers.
This is the command set i push via spi with bus pirate for read: datasheet: The instructions is initiated by driving the /CS pin low and then shifting the instruction code "48h" followed bya a 24-bit address(A23-A0) and eight "dummy clocks into the DI pin.
What i send: [0x48 0x00 0x00 0x00 0x00 0x00 r:256] <- read security register(read 256 bytes)
Each security register is 256 bytes in size and there are aparrantly 4 though i can only see 3 in the datasheet.
My questions is how would i read each security register 256 bytes at a time?
Section 8.2.33 is the reference and the the datasheet is here http://www.nexflash.com/NR/rdonlyres/A5B6C30B-C174-43CF-867E-E1A2F371A07C/0/W25Q128FV.pdf
  • \$\begingroup\$ [0x48 0x00 0x00 0x00 0x00 0x00 r:256] should be [0x48 0x00 0x00 0x00 0x00 r:256] ? Because there are 24 bits address (3 bytes) + 8 dummy bits (1 byte) = 4 bytes? \$\endgroup\$
    – diverger
    Commented Nov 24, 2014 at 12:46
  • \$\begingroup\$ sounds correct. how would i address each register? [0x48 0x00 0x01 0x00 0x00 0x00 r:256] -<register 1 ? \$\endgroup\$
    – TomTom
    Commented Nov 24, 2014 at 13:17
According to the datasheet, the 3 security registers' address range are:
Security Register 1 (256 Bytes): 0x001000 ~ 0x0010FE
Security Register 2 (256 Bytes): 0x002000 ~ 0x0020FE
Security Register 3 (256 Bytes): 0x003000 ~ 0x0030FE
So, read 256 bytes from one register (read entire register) with Pirate bus SPI command, should be like
read Security Register 1 ==> [0x48 0x00 0x10 0x00 0x00 r r:255 ]
  • \$\begingroup\$ what does it mean followed by 8 dummy clocks to the di pin? \$\endgroup\$
    – TomTom
    Commented Nov 25, 2014 at 2:11
  • \$\begingroup\$ "Dummy" clocks means these clocks won't clock in/out useful data, the internal implementation of the chip may need these clocks to do some "preparation" before it can give you useful data. \$\endgroup\$
    – diverger
    Commented Nov 25, 2014 at 2:26
  • \$\begingroup\$ ok so do i need to add these dummy clocks to the spi command? it does say instruction 48h followed by a 24bit address and eight dummy clocks into the di pin... how would i achieve this? really appreciate your help \$\endgroup\$
    – TomTom
    Commented Nov 25, 2014 at 2:31
  • \$\begingroup\$ You simply send the 3 bytes address, and then followed by 1 byte data (any is ok), and read. \$\endgroup\$
    – diverger
    Commented Nov 25, 2014 at 2:35
