I am sometimes really confused by the abusive use of jargon in EDA/VLSI design articles and books. With no precise definitions, its upto the reader to make interpretation which is very ambiguous and incorrect at times
Like,
  1. What is the difference between Pin accuracy and Bit accuracy ?
    Does pin-accuracy apply to communication interfaces and bit accuracy to computations. Can 't they be used interchangeably ?
  2. Is it correct to say that an RTL model has
    - Functional accuracy == Pin/Bit-accurate
    - Timing accuracy == cycle-accurate ??
    Which means that an RTL model when simulated produces precise results at each and every clock cycle. I have come across articles where author says Bit and cycle accurate models simulate faster than RTL models - which suggests that relatively RTL model simulations are slow because they are more precise in terms of functional and timing accuracy.
Can someone explain how(using VHDL or Verilog code) ?
The terms keep changing with the time, but one has to start looking at the definitions adopted by the standardization group of SystemC TLM2.0. The work led to the definition of two coding styles:
  • Loosely-timed (temporal decoupling, only sufficient timing detail to boot O/S and run multi-core systems)
  • Approximately timed (cycle approximate, cycle count accurate, enough details for architectural exploration)
1) The pin accuracy is at the interface level that is the communication part of the model. Transaction level modelling hides the pins by use of function calls between different processes. The functions are implemented either at the channel level or provided by Export mechanisms. As long as your testbench/model does not have the purpose to communicate with synthesis-ready RTL with real pins, TLM is usually sufficient and faster in terms of simulation time. Bit accuracy is how your data is being represented inside your Computation processes. It is the accuracy of your different datapaths be that ALU operations, DSP operations, Pixels representations, ... etc. In systemC for example, if you are not very concerned about the format of your data then you can as well use built-in C++ datatypes such as int to speedup the simulation time. But if you want to investigate the data from bit width perspective, truncation, saturation, .. etc then you should use systemC built-in datatypes and define your own size of the vectors. Drawback: slower simulation time. Now, you can see that both concepts are not necessarily correlated, as you can for example be in a situation where you want your computation model to be data format accurate (bit accuracy) whereas you care or less about how you send it/produce it for other processes and end up using TLM functions (No pin accuracy), and the other way around.
2) For an RTL model, functional accuracy doesn't necessarily mean bit accuracy. (We agreed that pin accuracy is out of the game here). You can ensure the correctness of the functionality without using a defined bit width in your model. If you are modeling a multiplier then you can write C=A*B into your model and the result is calculated by means of simulation software and compared to the result of your perhaps Pipelined RTL multiplier. The function/result is still correct as long as you use enough bits in your model but doesn't have to be exactly the same. Now for the timing accuracy, imagine that you have a SPI interface that reads sampled data from an ADC every 40 ns. In your RTL, you will use a clock, a counter, a condition to check the counter reached enough cycles to make 40 ns then initiate the read operation. You can do the same in your model by one single wait statement without even using a clock. Now, your model is not cycle accurate but it is timing accurate :)
  • \$\begingroup\$ Thanks for such a nice detailed answer. I am a bit aware about TLM that computation and communication are orthogonal concerns. So I understand your answer to first question. But I am bit confused about the answer to 2nd question. As I understand, code written in VHDL or verilog qualifies to be called RTL if it is bit-accurate, pin-accurate, cycle accurate ? \$\endgroup\$
    – nurabha
    Nov 24, 2014 at 17:47
  • \$\begingroup\$ An online article eetimes.com/document.asp?doc_id=1216014 states: "Cycle- and bit-accurate models simulate at about 30 to 100 times faster than the RTL models that have traditionally been used for integrated circuit verification." - it clearly compares RTL to cycle+bit-accurate model as if these two models are different ? I want to know what makes RTL simulation go slow w.r.t cycle+bit accurate model and how are they different ? \$\endgroup\$
    – nurabha
  • \$\begingroup\$ The following paper carbondesignsystems.com/… gives three definitions of cycle accuracy, one of them being cycle count accurate. \$\endgroup\$
    – nurabha
    Nov 24, 2014 at 17:49
