DS18B20 temp sensor IC Dq pin is connected to PSEN of controller in my application.
But in datasheet its mentioned that its connected to I/O port.
And second doubt is how I/O port senses temp? It should be connected to ADC pin of controller.
  • \$\begingroup\$ The DS18B20 doesn't need to be connected to an ADC, as it works digitally. You probably want to search about how to implement 1-Wire using your microcontroller (I'd guess it's an 8051 because you said PSEN). \$\endgroup\$
    – Renan
    Nov 25, 2014 at 12:03
  • \$\begingroup\$ Can we connect Dq to PSEN~ (PSEN bar)? PSEN~ is I/O pin? \$\endgroup\$ Nov 25, 2014 at 14:27
  • \$\begingroup\$ I don't know (never used the 8051) but from searching around, PSEN is not an I/O pin, therefore you can't. \$\endgroup\$
    – Renan
    Nov 25, 2014 at 20:57
DS18B20 is a digital Thermometer, thus you will not need any ADC. DS18B20 communicates with microcontroller through 1-wire protocol. You can also implement 1-wire protocol using GPIO. see below link for more details on software implementation of 1-wire protocol http://www.maximintegrated.com/en/app-notes/index.mvp/id/126
