I am using an STM32F429 CAN bus program with TJA1041A as the CAN transceiver. The problem is that the messages are not getting acknowledged, and herewith I am attaching the code for further reference. I am using PCAN-View to see the messages. Are there any faults in this code?
int main(void)
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN2, ENABLE);
    // SystemInit();
    GPIO_InitTypeDef GPIO_InitDef;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    GPIO_InitDef.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13;
    GPIO_InitDef.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitDef.GPIO_OType = GPIO_OType_PP;
    GPIO_InitDef.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_InitDef.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_Init(GPIOB, &GPIO_InitDef);
    /* Connect CAN pins to AF */
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_CAN2); // CAN2_RX
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_CAN2); // CAN2_TX
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
    GPIO_InitDef.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
    GPIO_InitDef.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitDef.GPIO_PuPd = GPIO_PuPd_NOPULL;
    /* Connect PD5 and PD7 pins for CAN transceiver to enable and
       standby. */
    GPIO_Init(GPIOD, &GPIO_InitDef);
    GPIO_SetBits(GPIOD, GPIO_Pin_5|GPIO_Pin_7);
    RCC_ClocksTypeDef     RCC_Clocks;
    CAN_InitTypeDef       CAN_InitStructure;
    CAN_FilterInitTypeDef CAN_FilterInitStructure;
    RCC_GetClocksFreq(&RCC_Clocks);
    CAN_DeInit(CAN2);
    CAN_StructInit(&CAN_InitStructure);
    /* CAN cell init */
    CAN_InitStructure.CAN_TTCM = DISABLE;
    CAN_InitStructure.CAN_ABOM = DISABLE;
    CAN_InitStructure.CAN_AWUM = DISABLE;
    CAN_InitStructure.CAN_NART = DISABLE;
    CAN_InitStructure.CAN_RFLM = DISABLE;
    CAN_InitStructure.CAN_TXFP = DISABLE;
    CAN_InitStructure.CAN_Mode = CAN_Mode_Normal ;
    /* Quanta 1+14+6 = 21, 21 * 4 = 84, 42000000 / 84 = 5000000 */
    /* CAN Baudrate = 500 kbit/s (CAN clocked at 42 MHz). Prescale = 4 */
    /* Requires a clock with integer division into APB clock */
    CAN_InitStructure.CAN_SJW = CAN_SJW_1tq; // 1 + 6 + 7  = 14,  1 + 14 + 6 = 21,
                                             // 1 + 15 + 5 = 21
    CAN_InitStructure.CAN_BS1 = CAN_BS1_14tq;
    CAN_InitStructure.CAN_BS2 = CAN_BS2_6tq;
    CAN_InitStructure.CAN_Prescaler = 4; // Quanta by Baudrate - 125 kbit/s.
    CAN_Init(CAN2, &CAN_InitStructure);
    /* CAN filter init */
    CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask; // IdMask or IdList
    CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_16bit; // 16 or 32
    CAN_FilterInitStructure.CAN_FilterIdHigh      = 0x0000; // Everything, otherwise 11-bit in top bits
    CAN_FilterInitStructure.CAN_FilterIdLow       = 0x0000;
    CAN_FilterInitStructure.CAN_FilterMaskIdHigh  = 0x0000;
    CAN_FilterInitStructure.CAN_FilterMaskIdLow   = 0x0000;
    CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_FIFO0; // Rx
    CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
    //CAN_FilterInitStructure.CAN_FilterNumber = 0; // CAN1 [ 0..13]
    //CAN_FilterInit(&CAN_FilterInitStructure);
    CAN_FilterInitStructure.CAN_FilterNumber = 14; // CAN2 [14..27]
    CAN_ITConfig(CAN2, CAN_IT_FMP0, ENABLE);
    CanTxMsg TxMessage;
    // Transmit */
    TxMessage.StdId = 0x321;
    TxMessage.ExtId = 0x00;
    TxMessage.RTR = CAN_RTR_DATA;
    TxMessage.IDE = CAN_ID_STD;
    TxMessage.DLC = 8;
    TxMessage.Data[0] = 0x02;
    TxMessage.Data[1] = 0x11;
    TxMessage.Data[2] = 0x11;
    TxMessage.Data[3] = 0x11;
    while(1)
        uint32_t i;
        int j = 0;
        uint8_t TransmitMailbox = 0;
        TxMessage.Data[4] = (j >>  0) & 0xFF; // Cycling
        TxMessage.Data[5] = (j >>  8) & 0xFF;
        TxMessage.Data[6] = (j >> 16) & 0xFF;
        TxMessage.Data[7] = (j >> 24) & 0xFF;
        j++;
        TransmitMailbox = CAN_Transmit(CAN2, &TxMessage);
        i = 0;
        while (  (CAN_TransmitStatus(CAN2, TransmitMailbox) != CANTXOK) &&
                 (i != 0xFFFF)
              ) // Wait on transmit
            i++;
            CAN2RX(); // Pump RX
  • \$\begingroup\$ Do you have another CAN device on the same bus, at the same baud rate as your development device and the PCAN monitoring device? Have you checked your terminations? \$\endgroup\$
    – Martin
    Commented Nov 25, 2014 at 12:55
  • \$\begingroup\$ I have PCAN view as another CAN Device to see tzhe messages and it is terminated by 120 ohms. \$\endgroup\$ Commented Nov 25, 2014 at 13:07
If your code is sending a message at all, you should get ACK. Put a scope on the lines and see if the problem is you're not sending, or a electrical problem that prevents the right signal levels.
The two usual mistakes people make to get no ACK is they forget to connect at least one other device to the bus and they forget to put the terminating resistors on the bus. If you want another device to send ACK, there has to be another device. Despite this being blatantly obvious, it is a suprisingly common brain fart according to my observations.
As for the terminators, they are not optional. Yes, they function to reduce reflections from the ends of the bus, and in that sense you could debug a short bus wihtout them. However, they also pull the bus lines together so that the bus is in the recessive state when nothing is actively driving it. This is not optional. This is a lot like the pull-up resistor on a open-collector bus is not optional. The terminators are pull-together resistors instead of pull-up, but can't be omitted for the same reason.
  • \$\begingroup\$ I have already checked the above things and I am able to see the transmitted messgaes from microcontroller to PCAN View in Oscilloscope but those messgaes are not being displayed in PCAN View..It throws an error message. \$\endgroup\$ Commented Dec 1, 2014 at 8:30
  • \$\begingroup\$ @user: It still sounds like you haven't actually looked at the signals with a scope. Without seening that the signals look good, you can't rule out a electrical problem. Otherwise, if the message is clearly being sent and the PCAN thing indicates error, then there is some mismatch. Most likely the bit rate is not set to the same on both ends. Again, looking at the signals with a scope will tell you what bit rate is really being used for sending, regardless of what you think is being used for sending. \$\endgroup\$ Commented Dec 1, 2014 at 14:35
  • \$\begingroup\$ Thanks for ur info.From the scope the bit rate is set to 500kbps and this is set at bith the ends.My Question is whether my SystemCLock of STM32 should be assigned to HSE or HSI Clock? \$\endgroup\$ Commented Dec 2, 2014 at 11:19
