So a few weeks ago, my boyfriend's 32" flat-screen TV popped like a firecracker while I was watching it (and scared the hell out of me!), followed by a burning smell. This is the third device of his to fail on my watch (the first and second being his hard drive and a lightbulb, which I recovered and replaced respectively)... It's just a string of bad luck, but I couldn't help feeling guilty, even though they failed through sheer coincidence and no fault of my own (honestly!).
I unscrewed the back panel and took a look inside. At first, I thought that it was just a popped resistor and some damage to the nearby connector. Upon further inspection, however, I noticed there's another spot on the bottom of the PCB that's popped and burned through. Also note the puffy capacitors, which probably caused the cascade of failures.
My primary question to you guys is: Can an average electronics specialist with standard soldering tools fix/replace all of the components that are damaged on this board? Or is it too far gone to attempt a repair without highly specialized equipment? Also, I've heard that some companies can make you a PCB given a schematic diagram... Think I could just ship this to one of them and have them make me a new one? :)
If so, my secondary question is: What kind of connector do I need to replace the damaged one? It's a linear 10-pin connector (as you can see in the picture), with a spacing of 2.25mm. Can I use any connector matching the shape and pitch requirements as long as I have a matching socket piece? And what kind of crimping tool do I need for the pins? I'll probably have to cut that whole end off since it's damaged.
Forgive my ignorance, as I'm a computer scientist and not an electrical engineer, but I'd just like to know whether it would be worth my time learning how to fix it, or if the whole thing should just be trashed.
