I'm putting together an ALU, that I want to synthesize on an FPGA. The carry-look-ahead adder is the one many choose to use as opposed to the ripple-carry adder. However, a thought crossed my mind. The ripple-carry adders I have put together before simply has a series of one bit full-adders connected to each other. My though is, what if I were to design a 4-bit full-adder? I'm not talking about an an adder made up of four one bit full-adders. I'm talking about a single components with 9 inputs (x3,x2,x1,x0,y3,y2,y1,y0,cin). I'm aware this would have 512 possible states (2^(9 inputs)).
What I'm wondering is:
- There is obviously going to be a massive number of gates used, is it worth it?
- If I were implementing all my components using NAND gates with a certain delay or all of this, how much of an improvement in speed would a see in a 32-bit using a.) 4-bit full adders b.) CLA adder c.) 1-bit full adders
- Is there some other implementation of an adder I'm not aware of.
- Although an adder is a very menial part of an ALU, what do most digital designers actual go for? Or do they simply use
assign Sum = X+Y+cin;
