I need to drive a circuit (operational current 150mA) with a USB port. I would like to protect the port with a fuse and from this question I concluded, that what I want is a PTC fuse. Is that the correct conclusion?
I would choose the MF-PSMF035X, but I am somewhat confused by all the different currents provided in the data sheet and can not really tell, if this fuse would "blow" (how do you say that for a resettable fuse?) earlier than the fuse on my motherboard, which I would want to not blow, of course.
So here is my interpretation of the different currents:
- \$I_{MAX}\$ = current at which the fuse gets destroyed
- \$I_{HOLD}\$ = normal operational current
- \$I_{TRIP}\$ = max current through "blown" fuse
- Max. time to trip [Amperes @ 23 C] = max. current it takes for the fuse to "blow"
Now the USB fuse of my motherboard should blow at 1.5A according to the USB specs. If my PTC "blows" at 8A, as it says in the sheet, then it would effectively NOT protect my MB, would it? And also \$I_{TRIP}\$ of 750mA is larger than the 500mA one can continuously draw from a USB port. Is that a problem?
Oh and additionally: what is the best thing to do with the data pins of a USB port, if I only need the power pins? I read somewhere, that you are supposed to short them, but that does not seem like a good idea to me.
