I am trying to read an analog signal using the Analog.Read() function and output 1 or 0 depending on the value of the analog signal. While testing using a serial monitor, I always get the symbol for 'phi'instead of 0 and the 'square box with question mark'instead of 1. Please help.
    const int analogInPin = A3;
    int inputValue=0;
    int ch1=1,ch2=0;
    void setup()
     pinMode(A0, INPUT);
     Serial.begin(9600);
    void loop()
      inputValue = analogRead(analogInPin);
      if(inputValue>240)
      Serial.print('1');
      else
      Serial.print('0');
      delay(10);
If I remember well you can use either:
Serial.print(1);
or
Serial.write('1');
To display 1 in the serial monitor.
  • \$\begingroup\$ I tried that too,but the same outcome with a different character. \$\endgroup\$ Commented Dec 3, 2014 at 19:14
  • \$\begingroup\$ You might try also Serial.print("1"); \$\endgroup\$
    – Roger C.
    Commented Dec 3, 2014 at 19:15
  • \$\begingroup\$ That doesn't work either. \$\endgroup\$ Commented Dec 3, 2014 at 19:18
  • \$\begingroup\$ You may have a problem somewhere else because I'm pretty sure that this code works. You could look to the TX line on the oscilloscope, to see what does generate the microcontroller. \$\endgroup\$
    – Roger C.
    Commented Dec 3, 2014 at 19:20
  • \$\begingroup\$ This is not related to the problem you're describing but in your code you're setting A0 as an input but reading from A3. \$\endgroup\$
    – Roger C.
    Commented Dec 3, 2014 at 20:05
If you're trying to output 1 or 0 simply remove your single quotes and use the following:
Serial.print(1);
Or
Serial.print(0);
Your code is printing out the ASCII value of 1 and 0...
