I soldered several pin rows on my pcb, and thought that both sides of the pcb are already connected. Therefore I only soldered the pin rows on the bottom of the pcb. Unfortunately they weren't connected, so that I have to solder the pin rows on the upper side of the pcb, too. But with my soldering tip I am not able to get below the pin rows. Is there a way to connect them without having to unsolder them?
Pictures:
1\$\begingroup\$ Can you post a picture? \$\endgroup\$– Some Hardware GuyDec 4, 2014 at 15:54
4\$\begingroup\$ Can you pry off the plastic part leaving the pins bare? \$\endgroup\$– Spehro PefhanyDec 4, 2014 at 15:59
\$\begingroup\$ Added pictures, @SpehroPefhany: I try to avoid that, because the pins can be unstable afterwards... \$\endgroup\$– arc_lupusDec 4, 2014 at 16:09
1\$\begingroup\$ You don't have to pry them all the way off, just half or three-quarters so you can get an iron under them. \$\endgroup\$– Matt YoungDec 4, 2014 at 16:10
1\$\begingroup\$ I never did with that many pins, but with maybe 2x6 I could relatively easy pull of the plastic parts without damage and put it back on again.... but ymmv \$\endgroup\$– PlasmaHHDec 4, 2014 at 16:20
1 Answer
Lever the plastic part up until it is at the top of the pins.
Hold each pin with angled needle-nose pliers (to prevent heat from melting the plastic) while soldering it to the top-side pad.
push the plastic back down.
