I am writing a parser (a finite state machine to be more precise) for AT-commands and I don't see how to handle a particular corner case:
Here is the specifications of the modem communication:
When the DTE sends an AT-command terminated by <CR>
(like ATE0<CR>
), the DCE will optionally answer an information text response between <CR><LF>
characters and finally give the final result code (like <CR><LF>OK<CR><LF>
My algorithm is like this:
do {
line = readLine(serial_modem);
} while (! is_final_result_code(line))
Here is the corner case:
Suppose I send the command to read an SMS message and that the information text response (i.e. the SMS text) itself contains the sequence <CR><LF>OK<CR><LF>
Then my parser will think wrongly that the first <CR><LF>
terminates the information text response while the next part is the final result code.
Do I miss an important information on how to handle this case properly ?
