I'm just wondering how I would go about getting the normal 5vdc that comes out of the Arduino analog/digital pins to a 0vdc signal? I wanting to mimic a push button (momentary switch) so that it acts as if I am pushing a button on a remote.
I'm sure I could use a resister of some value in order to get it down to 0vdc but I am unsure of that value nor am I sure that's the best way to go about doing something like this.
Any help would be great! Thanks!
update
Would using a TLP592A work doing it this way:
  • \$\begingroup\$ Just set an output pin low (logic 0) \$\endgroup\$ Dec 6, 2014 at 20:29
  • \$\begingroup\$ @PeterBennett Just because you set the output to low doesn't mean it will be 0 vdc. \$\endgroup\$
    – StealthRT
    Dec 6, 2014 at 20:42
    \$\begingroup\$ If you really want 0.0 volts, you'll have to drive a relay with an output pin, then the relay contacts will be the same as a switch connected to ground. \$\endgroup\$ Dec 6, 2014 at 20:46
  • \$\begingroup\$ I agree with the above - use the nIO pin to drive a transistor that turns on or off a relay. The relay contact acts just like a momentary switch and is isolated from the relay coil. \$\endgroup\$
    Dec 6, 2014 at 21:33
  • \$\begingroup\$ I'd rather get away without needing to use a relay. \$\endgroup\$
    – StealthRT
    Dec 6, 2014 at 22:05
What interface you will need depends on the circuit of the remote. If the switch shares a common ground with the Arduino then you might get away with just connecting directly to it. However for safety I would use a diode or transistor to provide an 'open collector' output. The circuit below shows how both a diode and transistor would be wired (choose one or the other, not both!).
Some remotes have their switches connected to battery positive, perhaps to make the transmitter turn on whenever a button is pressed. Others have buttons arranged in a matrix of rows and columns, so both ends of the switch may be floating. In these cases you can use an opto-coupler or PhotoMOS 'relay' (opto-coupler with FET output).
The circuit below shows how to use an opto-coupler. Note that the opto-coupler's output is polarity conscious, so you may have to swap pins 4 and 5 to get it working.
  • \$\begingroup\$ Please check my updated original post and see if I have this connected correctly. \$\endgroup\$
    – StealthRT
    Dec 7, 2014 at 2:58
  • \$\begingroup\$ Disconnect the wire going from pin 4 to Arduino Ground, and make a connection from pin 4 to pin 6. If it acts like the switch is permanently on then swap the wires going to the switch. And you need a resistor in series with pin 1 or 2 to limit current going through the LED. \$\endgroup\$ Dec 7, 2014 at 6:57
  • \$\begingroup\$ Would a 330ohm resister work for pin 1 then? \$\endgroup\$
    – StealthRT
    Dec 7, 2014 at 21:01
  • \$\begingroup\$ Yes. A 330 Ohm resistor should set LED current to ~10mA. \$\endgroup\$ Dec 7, 2014 at 22:33
  • \$\begingroup\$ Bruce, the +5V is the Arduino 5vdc pin, correct? And the 330ohms is connected to one of the digital pins on the Arduino, correct? And i also bought the 4N25 instead of the 4N37-will that work with this? \$\endgroup\$
    – StealthRT
    Dec 15, 2014 at 4:39
