I dissected and drew up this oscillator circuit from a cassette machine the other night. It's purpose is for biasing the tape. I'm curious though as to how this oscillator functions since the base is not grounded. It measures a negative dcv at the base. It produces a clean hv ac sine wave after the 562 cap... but why, or how? What is the purpose of the bypass cap in the circuit? What would happen if the input voltage were increased?
Update The TO-92 says c3377 which seems comparable to a 2sc3377 npn transistor.
Also, I have been researching transistors without bias and came across this... "Ever wondered why VBE is always quoted as 6V for silicon transistors? The reason is that a zenner effect takes place at around 8V. Now, if you actually use a significantly higher voltage, but current limited via a resistor, then the zenner effect will allow enough base leakage current to pass to make the device conduct as if a bias had been applied. This conduction holds the emitter (now collector) at this zenner voltage." Is it possible this is how the circuit is functioning? After quadruple checking the pcb there are definitely no bias resistors on the base.
I have some parts coming and will breadboard it to verify the schem too.
    \$\begingroup\$ The circuit is not right because the transistor is not biased at all. Try tracing it out again. Also, are you sure it's a BJT? \$\endgroup\$
    Commented Dec 8, 2014 at 10:15
  • \$\begingroup\$ That's a good question... I assumed it was a BJT because it's in a to-92 package, but maybe it's not. I'll look more closely at it today. \$\endgroup\$ Commented Dec 8, 2014 at 16:27
  • \$\begingroup\$ What is 'high ac out' connected to? Are you sure that Base and Emitter are the correct way around? \$\endgroup\$ Commented Dec 8, 2014 at 22:59
  • \$\begingroup\$ The High ac out goes to the erase head. The only way I can tell for sure about the pinout is to take it out and test it... I'll do that tonight. \$\endgroup\$ Commented Dec 8, 2014 at 23:32
  • \$\begingroup\$ Have you tried simultaing it? \$\endgroup\$
    – pjc50
    Commented Dec 9, 2014 at 0:15
My guess is that you have the Base and Emitter swapped over. Here's an example that is similar to yours. Note how inductor L3 is connected (through R5) to the Emitter, and the erase head is connected from ground (through R3) to the Base.
Tape Recorder Erase Oscillator
The circuit is based on a Common Collector Colpitts oscillator. The erase head in combination with C6 and C7 form a tuned circuit. The tap between the two capacitors lowers the impedance on the Emitter side, providing the power gain and positive feedback required to make it oscillate.
  • \$\begingroup\$ OK Yes! I tracked down the datasheet for 2sc3377 which seems to be the tr used in the circuit, and sure enough, the pinout is reversed. Your provided schem is quite similar to the other when properly drawn. Thank you for the direction. I'll probably have more??? later but your answer helps with studying it (: Thx \$\endgroup\$ Commented Dec 9, 2014 at 2:19
