Please help me with this. I'm trying hard to get the specific answer. I want to know a particular answer. What we use in mobile phones? Micro-controller or microprocessor? Or both?
You might want to read the following to understand the issue:
What's the difference between a microcontroller and a microprocessor?
Simple cellular phones that do little more than voice and text calling typically consist of one processing unit that handles everything - user interface (keyboard, display), RF processing, battery management, etc.
These are SoC - Systems on Chip and are closer to microcontrollers than microprocessors because they attempt to do everything - from processing, to device interfacing, to memory, to program and data storage, etc - on one chip.
Smartphones have multiple microprocessors and microcontrollers in them. The main processor is a microprocessor with a bus to communicate with memory on separate chips (though often contained in the same IC package), and busses to communicate with the rest of the devices. They usually contain some of the controllers, such as the display controller, so they have some of the features of microcontrollers, but they are still more microprocessor than microcontroller. The cellular chipset usually includes a microprocessor/microcontroller that really blurs the lines. The latest generation of smartphones often tend more toward microprocessors for the RF chipset, so as to offer the manufacturer flexibility by using software design rather than hardware design for some features, but they do have more pieces of the hardware interface (rf, etc) on the chip itself.
The rest of the phone has several microcontrollers. These control the touchscreen, audio, sensors, cameras, etc.
So it depends on the type of phone you're thinking of. A simple phone uses a microcontroller. A complex phone uses both.
| improve this answer | |
I'd say neither of both, but a system-on-chip, or SOC. But also a microcontroller (see pjc50's comment), or both.
A SOC has the CPU of course, but it can also also incorporate the GSM module, display controller and some memory onboard. In smartphones, it can also feature a graphic accelerator, WiFi and Bluetooth modules, GPS module and so on. In any case, compared to a microcontroller it's more powerful and more power-hungry.
Generally, manufacturers try to have as most features as possible on just one SOC, as it reduces cost, complexity and power consumption. Other functions can be (and often are) implemented on a separate chip, such as the display driver or coprocessors.
Typically, phones also have external RAM and flash memory, but that could also be used with microcontrollers.
  • \$\begingroup\$ While that holds true for smartphones, it doesn't hold true for all mobile phones. You don't need a SoC for a small "normal" (i,e., no touch screen, no fancy graphics, no web browser, real buttons, etc) mobile phone. \$\endgroup\$ – Majenko Dec 8 '14 at 9:52
  • \$\begingroup\$ @Majenko:Does this mean that a GSM based mobile communication device for Voice and Text data can be implemented using a micro-controller (like 8051) or a microprocessor (like 8086) ? \$\endgroup\$ – control Dec 8 '14 at 10:02
  • \$\begingroup\$ I see you're trying to cram the answer into one of two boxes neither of which really fits but presumably are on the homework ... I don't think you could really implement a full GSM device with either of those two. Have a look at an ultra cheap phone bunniestudios.com/blog/?page_id=3107 : the processor is one of these ( ccc-cn.net/mt6250 ), which is an ARM7 and a number of signal processing peripherals on a single chip. \$\endgroup\$ – pjc50 Dec 8 '14 at 10:07
  • \$\begingroup\$ @Majenko sorry, indeed I made that assumption. But in fact, while not an ARM, it might be that feature phones also use something similar \$\endgroup\$ – clabacchio Dec 8 '14 at 10:09
  • \$\begingroup\$ I think you do need quite a bit of DSP capability to handle the GSM side. If we go back to the very early GSM phones: eevblog.com/2013/07/10/… we find a Motorola MC68332 freescale.com/webapp/sps/site/prod_summary.jsp?code=MC68332 which is listed as a "microcontroller". Again, neither the 8051 or the 8086 is realistically going to be powerful enough on its own. \$\endgroup\$ – pjc50 Dec 8 '14 at 11:18
