I am a newbie to this MSP430. So, please tell me when I go wrong.
I have a final project making MPPT (Maximum Power Point Tracker) using MSP430G2231. The basic idea is to measure to Analog input (voltage and current), then multiply it (power) and compare to the previous result. That's why, before going further to the algorithm of the MPPT itself, I am trying to use this MSP430G2231 to read 2 analog input and create PWM using it.
I use two pins as an input, P1.0 and P1.1. Then, I use P1.2 to produce the PWM. The coding that I made goes like this:
#include <msp430.h>
#include "msp430g2231.h"
//Global Variable
unsigned int AdcData[2] ; // Store results A1,A0
unsigned int Current ; // store value from P1.0
unsigned int Voltage ; // store value from P1.1
void main (void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 = CALBC1_1MHZ; // Set range
DCOCTL = CALDCO_1MHZ; // SMCLK = DCO = 1MHz
ADC10CTL1 = INCH_1 + CONSEQ_1; // A1/A0, single sequence
ADC10CTL0 = ADC10SHT_2 + MSC + ADC10ON + ADC10IE;
ADC10DTC1 = 0x02; // 2 conversions
ADC10AE0 |= 0x03; // P1.1,0 ADC10 option select
P1DIR |= BIT2; // P1.2 = output
P1SEL |= BIT2; // P1.2 = TA1 output
TACCR0 = 1024-1; // PWM Period
TACCTL1 = OUTMOD_7; // TACCR1 reset/set
AdcData[0]=32;
AdcData[1]=16;
Voltage = AdcData[0];
Current = AdcData[1];
TACCR1 = (Voltage*0.04)*(Current*0.05); // TACCR1 PWM Duty Cycle
TACTL = TASSEL_2 + MC_1; // SMCLK, upmode
while (1)
__bis_SR_register(LPM0_bits + GIE); // LPM0, ADC10_ISR will force exit
ADC10SA = (unsigned int)&AdcData; // Data transfer location
ADC10CTL0 |= ENC + ADC10SC; // Start sampling
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
__bic_SR_register_on_exit(LPM0_bits); // Exit LPM0
I try to trace it using "step into" in debugging mode. Everything seems goes well until it reach this line :
When the pointer reach that line, the "step into" button is not active anymore which means there's something wrong.
Do I write the algorithm right, especially when assign the values from ADC to the AdcData? And, I can multiply the output value from ADC right and then use it to generate PWM?
In response to jsolarski answer (thank you for giving me feedback)
Actually I've been writing the algorithm like you mention and it goes like these and it still not working
for (;;)
ADC10CTL0 &= ~ENC;
while (ADC10CTL1 & BUSY); // Wait if ADC10 core is active
__bis_SR_register(CPUOFF + GIE); // LPM0, ADC10_ISR will force exit
//code from reading from res and sending it to AP
__bic_SR_register_on_exit(CPUOFF); // Clear CPUOFF bit from 0(SR)
I don't use this code: P1OUT |= 0x01;
because I use that Pin for ADC input.
And this line,
ADC10SA = 0x200; // Data buffer start
ADC10SA
means ADC10
Start Address right, where you want to transfer the ADC conversion value? So, when I want to transfer it to my AdcData array, is it okay to write it like it did?
