I want to make a 50Amps switching power supply, I have already done 10A linear ones succesfully
This time it has to be a switching power supply one so, any ideas or tips of where to start are appreciated
IF I succed and works as intended this will end up being used to power a high power laser at a research center, but if I fail nothing bad will happen, I just want to have the chance to work in this project and as I said, I do this more for the experience than anything
I do know its not an impossible task, but not a trivial one, either however I need some ideas of where to start
    \$\begingroup\$ Did your shift key break? Earlier today it was working. \$\endgroup\$ – Nick Alexeev Dec 10 '14 at 7:18
  • \$\begingroup\$ 50A at what voltage? High power switch mode power supplies are not trivial but certainly achievable. \$\endgroup\$ – Warren Hill Dec 10 '14 at 7:18
  • \$\begingroup\$ @NickAlexeev it looks like the only emphasis he wanted was on "IF" haha. Maybe it's a hidden writing style. \$\endgroup\$ – KyranF Dec 10 '14 at 7:20
  • \$\begingroup\$ 12v, i was wondering about the possibility of making it variable but i sill dont know if this is possible \$\endgroup\$ – GoatZero Dec 10 '14 at 8:15
If you're looking for an in-depth/academic approach to learning about the theory behind switching power supplies, the power electronics class on Coursera is a good place to start. You'd probably only need to take the first six weeks unless you want to design the controller too. You will need a decent background in analog circuit theory (undergrad EE is fine). Doing the homework will vastly improve your understanding.
