I know I'm asking a basic Question. But it will be very useful for me to continue my Micro-controller Experience. Consider I am using a controller with 256 KB Flash and 8 KB Ram. My Questions are
  1. I know about memory mapping like code, Data, Stack and Heap Segment, which variable will store in which segment. But are these allocated in RAM or Flash
  2. If I am declaring a buffer, I know it is allocating in RAM. Whether it will deallocate after the function ends (if that Buffer is Locally declared)
  3. Where the Register Variable will allocate the memory.
  • \$\begingroup\$ Your questions are much better suited for stackoverflow, I'm afraid. \$\endgroup\$
    – Dzarda
    Dec 10, 2014 at 13:56
    \$\begingroup\$ @Dzarda It's a bit of a grey area. While some of it is general programming theory, some (like what goes in flash and what in RAM) is more MCU specific, so fits here. \$\endgroup\$
    – Majenko
    Dec 10, 2014 at 13:58
    \$\begingroup\$ @Cool_Binami Can you explain what you mean in part 3? \$\endgroup\$
    – Majenko
    Dec 10, 2014 at 14:20
    \$\begingroup\$ @Dzarda He might mean SFRs though. Clarification is needed. \$\endgroup\$
    – Majenko
    Dec 10, 2014 at 14:38
    \$\begingroup\$ The register keyword was never more than a hint to the compiler, and is ignored by (almost?) all modern C / C++ compilers. \$\endgroup\$ Dec 10, 2014 at 18:11
15
Everything is done in "sections". Where a section goes depends on its use. What gets put into a section, again, depends on its use.
In general you get two "data" sections - .data and .rodata. .data is stored in RAM and is read-write. .rodata is stored in Flash and is read-only.
Things that are "const" generally end up in .rodata. Literals (string, numeric, etc) also end up in .rodata.
For instance, these would normally be stored in Flash:
const char *foo = "foo";
const int bar = 234;
"baz" (string literal)
These will be stored in RAM:
char foo[10];
int bar;
But then of course, it can be more MCU specific, especially when you get into Harvard (split RAM / Flash address spaces) architecture, where accessing data stored in Flash can be more of a special task and not done as normal variables. For instance, the const char *foo="foo"; would be copied into RAM for easy access during the initialization of the program.
When you allocate a variable of any size within a function, such as:
void func() {
    char mybuf[100];
the variable will be allocated as part of the stack (or an emulated stack-like system using static variables on MCUs with a limited hardware stack, such as low-end 8-bit PICs). As soon as you return from the function all the stack space is reclaimed.
However, if you allocate it using malloc():
void func() {
    char *mybuf = malloc(100);
it will be allocated on the heap, and it is your responsibility to reclaim that space using free().
The register keyword, as in:
int register foo;
will, if a register can be allocated, store the data purely within that allocated register. It will never touch RAM, and consequently it will run faster. However, if a register cannot be allocated (they're all in use in the code) then the register keyword will be ignored and the variable allocated in RAM as per normal. One thing to note:
char register *foo;
That will only hold the pointer to the data in a register, not the data itself. The data itself will still be in RAM.
In general, though, the use of the register keyword is frowned upon since the compiler's optimizer usually does a better job, and using register can in fact cause other parts of your code to not be optimized as well and end up more complex than they would otherwise be.
    \$\begingroup\$ As a sidenote: On the avr-gcc platform for example, both .rodata and .data reside in RAM and are automagically loaded from flash on startup - unless you specify a variable with the PROGMEM attribute. \$\endgroup\$
    – Dzarda
    Dec 10, 2014 at 14:40
    \$\begingroup\$ @Dzarda Yes, because of the Harvard architecture I mentioned in paragraph 4. You have to use special functions / registers to gain access to it, so many systems also duplicate it in crt0 into RAM for ease of access. \$\endgroup\$
    – Majenko
    Dec 10, 2014 at 14:43
    \$\begingroup\$ @DaveTweed Agreed. I've enhanced it to mention that. \$\endgroup\$
    – Majenko
    Dec 10, 2014 at 15:12
    \$\begingroup\$ There are other sections in addition to the "data" sections that Majenko described. Most significant is the .text section, which contains the executable code and is typically stored in flash. Microcontrollers have more flash than RAM because applications typically require more code than data. \$\endgroup\$
    – kkrambo
    Dec 10, 2014 at 17:18
    \$\begingroup\$ register is indeed considered unnecessary these days but volatile keyword is still useful / relevant to indicate data which may change by some external means in between accesses - fro example, the contents of MCU's peripheral registers, variables changed by an interrupt service routine, that sort of thing. \$\endgroup\$
    – John U
    Dec 10, 2014 at 17:54
ARM memory mapping - The entire code(along with variable's ,code etc ) goes to ROM. Since this a read only memory and variables have to change, variables are in turn remapped into the RAM. So your RAM will be stack + global variables + static variables + heap(if any dynamic memory allocation). Local variables within functions are allocated within the stack and deallocated after the function exits
