Im facing some issues to figure out sequence of my bipolar(specifically) and unipolar stepper motor. However , I've managed to get Dual H Bridge but couldn't find out the example/documentation for the one i got.
I want to drive my bipolar stepper motor via dual h bridge using parallel port and unipolar via IC UN2003.
You're expert guidennce for pulse sequence and wiring identification will be truly appriciable. Thanks!!
Pictures
DUAL H BRIDGE : https://i.stack.imgur.com/eLruy.jpg
Stepper Motors scavenged from printers : https://i.stack.imgur.com/SN15A.jpg
Please do improve the answer if you can as i really dont know much electronics .
However, I'm able to understand and get very good explanations and documentation from of-course THE WEB.
STEPPER MOTOR WIRING AND SEQUENCE
WIRE TRACING WITH MULTIMETER
This tutorial helped to trace coil/wiring using multimeter (that stupid to not even determine coil)
http:// 42bots .com /tutorials/stepper-motor-wiring-how-to/ (remove space)
STEPPING SEQUENCE
This very good demonstration helped alot to figuring out pulse sequence.
http:// www. youtube .com/watch?v=kAyDmovM18E (remove space)
DUAL H BRIDGE
helpful documentation
https:// www. bananarobotics .com/shop/How-to-use-the-L298N-Dual-H-Bridge-Motor-Driver (remove space)
PARALLEL PORT
Once i understand the above mentioned and able to create logic i use I/O in c/c++ outb(); to interface stepper motor.
I need to study more to get control of speed and torque
  • \$\begingroup\$ It's good you got it sorted out but answers are supposed to be useful for others in the future. Maybe you could add some more details or a schematic of your working solution? \$\endgroup\$
    – PeterJ
    Dec 24, 2014 at 10:21
  • \$\begingroup\$ I will for sure later when i get free from work. Ive gone through alot to get simple answer \$\endgroup\$ Dec 24, 2014 at 10:25
  • \$\begingroup\$ Tell us what you've read, and what experiments proved to be insightful. \$\endgroup\$ Dec 24, 2014 at 18:33
  • \$\begingroup\$ Hope i tried as you might expected..thanks anyway. \$\endgroup\$ Dec 24, 2014 at 19:53
