I am experimenting with a PIC16F84A at the moment.
I can get this working fine using an RC network for the clock.
When I switch to using a crystal (the usual xtal across pins 15&16 with 2 caps going to ground from the same pins) I am not getting any clock at all.
The PIC is the 20MHz version, and I have tried all the crystals I have - 4MHz, 14.3MHz and 25MHz, and numerous different capacitors rangeing from 22pf right up into the uF range, but all I get is what appears to be a logic high on pin 15 and a logic low on pin 16.
Yes, I have changed the program config to be _XT_OSC (I have tried them all), but to no avail.
I am using gpasm to assemble the program and pk2cmd to flash the PIC in circuit under Ubuntu.
Any clues?
Edit: diagram:
            22pf
16 o----+---||----+
       |=|Xtal    +---+
        |         |   _
15 o----+---||----+   - GND
            22pf
(a little crude, I know ;) )
| improve this question | | | | |
    \$\begingroup\$ 22pF may be even too high. Try 12-18pf range. Also, are you using a breadbord? \$\endgroup\$ – Hans May 14 '11 at 15:34
    \$\begingroup\$ Ohkay - if I run it in HS oscillator mode, and ditch the capacitors (just have a crystal linked between pins 15 and 16) I get it working. If I then add the capacitors it stalls. Well, I say stalls - it appears to possibly be working at about 0.1Hz. \$\endgroup\$ – Majenko May 14 '11 at 16:27
    \$\begingroup\$ Solderless breadboards can be troublesome, especially for circuits involving crystal oscillators; I never use them. Try putting it on a PCB. \$\endgroup\$ – Leon Heller May 14 '11 at 16:48
    \$\begingroup\$ Do not stay too long with the 16F84. It is obsolete, expensive, limited in capability. Try 16F88 instead: finitesite.com/d3jsys/16F88.html \$\endgroup\$ – markrages May 14 '11 at 16:55
    \$\begingroup\$ @MattJenkins, it is actually the input capacitance and inductance of the scope probe that often kills the xtal when you touch it. Second, as pointed out, too much capacitance can often be a larger issue then too little. \$\endgroup\$ – Kortuk May 15 '11 at 6:41
You might have too much capacitance on the oscillator pins this can be caused by:
  1. Using the wrong capacitors for the selected oscillator/crystal.
  2. Building your circuit on a breadboard which increases capacitance in the circuit.
  3. Connecting a scope probe to the oscillator circuit.
When measuring the oscillator frequency it is best to connect the probe to the oscillator through a buffer. The PIC microprocessors often have a CLKOUT pin that serves this function, but it can only be used in some oscillator modes.
| improve this answer | | | | |
Add a 1Meg Ohm resistor in parallel with your xtal
    \$\begingroup\$ can you elaborate on your answer? \$\endgroup\$ – jsolarski Jun 15 '11 at 12:14
    \$\begingroup\$ I think what he's thinking of is a bias resistor to keep the CMOS inverter near its threshold region. This is necessary when using a CMOS inverter as the gain element in a crystal oscillator. PICs already have this built in. I've done over 100 PIC projects and never needed to add a external bias resistor. However, I have seen Microchip mention it on occasion. I don't think this was a dumb suggestion deserving a downvote, so I'm upvoting it to cancel that out. \$\endgroup\$ – Olin Lathrop Jun 25 '11 at 12:42
  • \$\begingroup\$ @Olin - I guess it was downvoted for lacking detail, not for being wrong. \$\endgroup\$ – stevenvh Jun 25 '11 at 13:30
-2
I've always been able to solve this problem by reducing, or often totally eliminating the capacitors. I've had this problem more times than I care to count, but it's never failed to fix the problem.
  • \$\begingroup\$ Hm, I don't know if I can recommend this. My experience is that on most oscillators this has an adverse effect. \$\endgroup\$ – stevenvh Jun 25 '11 at 12:27
  • \$\begingroup\$ I agree with stevenvh. Without any caps it could start oscillating at overtone frequencies. Also, without the right load on the crystal, the frequency will likely be a little out of spec, even if it oscillates at the fundamental. \$\endgroup\$ – Olin Lathrop Jun 25 '11 at 12:39
